Export Multiple
jahbuzzz
Export Multiple
Post by jahbuzzz » Sat Jan 15, 2011 6:02 pm
Hi there,
I used to be able to record an LP and then split it up into seperate tracks using Export Multiple. Now the option to split the tracks isnt there any more (used to be cmnd b I think)
Anyone help?
billw58
Re: Export Multiple
Post by billw58 » Sat Jan 15, 2011 7:32 pm
CMD+B is the shortcut for "Add Label at Selection". If that command is not available is probably means you are in Pause mode instead of Stop mode.
-- Bill
jahbuzzz
Re: Export Multiple
Post by jahbuzzz » Sun Jan 16, 2011 10:51 am
Thanks Bill. I'm definitely in 'stop' mode though...
billw58
Re: Export Multiple
Post by billw58 » Sun Jan 16, 2011 4:07 pm
Have a look a this tutorial: http://manual.audacityteam.org/man/Spli ... ate_tracks
-- Bill
