Reel to reel conversion - old equipment
bgravato
Re: Reel to reel conversion - old equipment
Post by bgravato » Tue Jan 18, 2011 12:30 pm
Audacity, if downloaded from the official website (the one wax posted), doesn't come with any adware.
Direct link for windows download page is this: http://audacityteam.org/download/beta_windows
Scroll down a bit on that page and you'll see a link for Audacity 1.3.12 installer.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
RussellXPD
Post by RussellXPD » Tue Jan 18, 2011 6:47 pm
Thanks WC
I should have known - I get emails from sourceforge etc.
I'd still like to know how Hotbar gets its hands on Google rankings - and even CNet, as far as I can tell, supplied the dodgy version. Correct version now in place.
Russ
RussellXPD
Post by RussellXPD » Fri Jan 21, 2011 10:22 am
This is a sign off (on this issue) and thanks to all who helped.
The ordered connector arrived and was put to work. I managed to get sound recorded as you said I would, and in the same way as other signals coming in on the Line In socket.
Unfortunately the sound signal was not up to standard and won't do. However I'm working with known quantities now: if this tape recorder won't do the job, another one will, and you guys have helped me get there far faster than if I'd been without your help online. Thanks again.
Russ
Trebor
Post by Trebor » Fri Jan 21, 2011 10:39 am
RussellXPD wrote:Unfortunately the sound signal was not up to standard and won't do.
There is a volume slider control in Windows audio devices to control the level of the "line-in" signal ...
http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel
The setting of this line-in volume level can effect soud quality, (i.e. try different settings).
[on XP} To open Sounds and Audio Devices, click Start, click Control Panel, click Sounds, Speech, and Audio Devices, and then click Sounds and Audio Devices
http://www.microsoft.com/resources/docu ... x?mfr=true
RussellXPD
Post by RussellXPD » Sun Jan 23, 2011 11:43 pm
Thanks, Trebor.
I found I got different results on screen but I can't test the machine properly till tomorrow.
R
RussellXPD
Post by RussellXPD » Mon Jan 24, 2011 6:46 pm
I tested the machine and know a bit more now.
Your post was of interest Trebor, because I didn't know about those Volume options within the Audio tab, although I've had a workaround which meant it was never a problem. Thanks.
In this case though, the machine is not delivering the right sound at the outset and it needs to be serviced. If anyone knows of a service agent in the Exeter - Taunton - Weymouth area, a wide sweep, I would be interested.
"The impossible takes a little bit longer."
Russ
