Pre Record Audio Metering
Re: Pre Record Audio Metering
Post by kozikowski » Wed Sep 12, 2007 5:06 am
<<<I should also add that they should unambiguously tell you which input they're monitoring.>>>
That doesn't happen by looking at the input selector in the middle of the menu banner? You lost me there.
<<<spot-free, lab-coat boring.>>>
I bet you don't get very many LOLs. I do have to watch the left-brain right-brain thing. Write clearly and with just enough color that the audience may have to stop and ROFL every so often. Leave room between the chairs and try not to scare the cat.
Helena, but there appears to be a "Capitol, Montana" zip 59332.
Just in case.
alatham
Post by alatham » Wed Sep 12, 2007 1:49 pm
kozikowski wrote:<<<I should also add that they should unambiguously tell you which input they're monitoring.>>>
Well, that input selector only works for specific drivers. It's blank on my install at home using my M-Audio card.
Furthermore, the meter is limited to only 2 channels. Sometimes I record 5 channels at once, I wish the meter would expand in those cases.
Post by kozikowski » Thu Sep 13, 2007 5:59 pm
<<<input selector only works for specific drivers>>>
<<<I wish the meter would expand in those cases>>>
This is me writing that down.
