Audacity...Stop Helping Me.
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
Post by kozikowski » Fri Jan 14, 2011 9:54 pm
The job is to trim an arbitrary amount of work from a show. The show is 48000, 16-bit, Stereo. I changed the Audacity Preferences to 48000, 16-bit, Stereo and turn dithering off. Delete x seconds from the end of the show. I Export a new file at 48000, 16-bit, Stereo and do I get a bit for bit copy except for the trimmed material and maybe certain file housekeeping at either end? Does Audacity still insist on converting to 32-floating in the middle or perform other conversions?
billw58
Re: Audacity...Stop Helping Me.
Post by billw58 » Fri Jan 14, 2011 10:38 pm
kozikowski wrote:Does Audacity still insist on converting to 32-floating in the middle or perform other conversions?
It seems nobody knows if Audacity converts to 32-bit float internally when doing an export. But turning high quality conversion dither off should give you a bit-for-bit copy of the unaltered portion of the show.
-- Bill
Post by kozikowski » Fri Jan 14, 2011 11:43 pm
It ought, oughtn't it?
Post by steve » Fri Feb 04, 2011 2:28 pm
billw58 wrote:It seems nobody knows if Audacity converts to 32-bit float internally when doing an export.
I seem to remember a discussion on the developers mailing list that mentioned that "mixing" is always done 32-bit float.
When Exporting, all non-muted tracks are "mixed" (for "Export Selected" it is all non-muted selections). This happens regardless of the number of tracks - there is no exception for a single track.
kozikowski wrote:It ought, oughtn't it?
You can test that by doing a checksum of a 16-bit wav file, import and export it again, then do a checksum of the new file (but watch out for changed metadata).
On Linux you can use:
Code: Select all
cmp file1 file2
There may be something similar on other operating systems.
