Windows Vista SP2 32 bit, fully updated to today.
Audicity 1.3.12 beta (unicode)
Preferences/Libraries. FFmpeg library not found.
Locate
Runtime Error!
Program C:program FilesAudacity 1.3 Beta (unicode)audacity.exe
r6034
An application has made an attempt to load the C runtime library incorrectly
Please contact the application's support team for more infornation.
Error repeats six times as you press ok, eventually giving the Locate FFmpeg window. Point to avformat-52.dll and hit ok.
Same error six times again, and back to Audacity Preferences and FFmpeg library not found.
I've attempted running as administrator, and not, I've attempted various "compatibility" settings, and not.
No difference.
Help?
1.3.12 beta problem finding/loading ffmpeg dll
rboatright
- Quality Assurance
Re: 1.3.12 beta problem finding/loading ffmpeg dll
I assume you downloaded and installed Audacity following:
http://manual.audacityteam.org/index.ph ... Ins#ffdown
Please start Audacity again, try to locate FFmpeg in Preferences then open Help > Show Log and copy and paste the contents into your reply.
rboatright
Here is the log per your request:
14:56:54: Trying to load FFmpeg libraries
14:56:54: mLibAVFormatPath is not empty, = C:Program FilesFFmpeg for Audacityavformat-52.dll. Loading from it.
14:56:54: Looking up PATH...
14:56:54: PATH = C:Program FilesSafari;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:Program FilesCommon FilesRoxio SharedDLLShared;C:Program FilesCommon FilesRoxio Shared10.0DLLShared;C:Program FilesJavajdk1.6.0_13lib;c:usersrickgwtantbin;C:Program FilesJavajdk1.6.0_13bin;C:androidandroid-sdk-windows-1.6_r1tools;C:Program FilesPalmSDKbin;C:Program FilesPalmSDKbinnovacom;C:Program FilesCalibre2;C:Program FilesPalmSDKbin;C:Program FilesPalmSDKbinnovacom
14:56:54: Checking that C:Program FilesFFmpeg for Audacity is in PATH...
14:56:54: not in PATH!
14:56:54: Appending ;C:Program FilesFFmpeg for Audacity ...
14:56:54: Loading avformat from C:Program FilesFFmpeg for Audacityavformat-52.dll
14:56:56: Error: Failed to load shared library 'C:Program FilesFFmpeg for Audacityavformat-52.dll' (error 1114: a dynamic link library (DLL) initialization routine failed.)
14:56:56: Loading avutil from C:Program FilesFFmpeg for Audacityavutil-50.dll
14:56:56: Loading avcodec from C:Program FilesFFmpeg for Audacityavcodec-52.dll
14:56:57: Error: Failed to load shared library 'C:Program FilesFFmpeg for Audacityavcodec-52.dll' (error 1114: a dynamic link library (DLL) initialization routine failed.)
14:56:57: Error: Failed to load shared library 'C:Program FilesFFmpeg for Audacityavformat-52.dll' (error 1114: a dynamic link library (DLL) initialization routine failed.)
14:56:57: Returning PATH to normal...
14:56:57: Failed to load FFmpeg libs
14:56:57: Trying to load from default path C:Program FilesFFmpeg for Audacityavformat-52.dll.
14:56:57: Looking up PATH...
14:56:57: PATH = C:Program FilesSafari;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:Program FilesCommon FilesRoxio SharedDLLShared;C:Program FilesCommon FilesRoxio Shared10.0DLLShared;C:Program FilesJavajdk1.6.0_13lib;c:usersrickgwtantbin;C:Program FilesJavajdk1.6.0_13bin;C:androidandroid-sdk-windows-1.6_r1tools;C:Program FilesPalmSDKbin;C:Program FilesPalmSDKbinnovacom;C:Program FilesCalibre2;C:Program FilesPalmSDKbin;C:Program FilesPalmSDKbinnovacom
14:56:57: Checking that C:Program FilesFFmpeg for Audacity is in PATH...
14:56:57: not in PATH!
14:56:57: Appending ;C:Program FilesFFmpeg for Audacity ...
14:56:57: Loading avformat from C:Program FilesFFmpeg for Audacityavformat-52.dll
14:56:57: Loading avutil from C:Program FilesFFmpeg for Audacityavutil-50.dll
14:56:57: Loading avcodec from C:Program FilesFFmpeg for Audacityavcodec-52.dll
14:56:58: Error: Failed to load shared library 'C:Program FilesFFmpeg for Audacityavcodec-52.dll' (error 1114: a dynamic link library (DLL) initialization routine failed.)
14:56:58: Error: Failed to load shared library 'C:Program FilesFFmpeg for Audacityavformat-52.dll' (error 1114: a dynamic link library (DLL) initialization routine failed.)
14:56:58: Returning PATH to normal...
14:56:58: Failed to load FFmpeg libs
14:56:58: Trying to load from system paths. File name is avformat-52.dll
14:56:58: Looking up PATH...
14:56:58: PATH = C:Program FilesSafari;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:Program FilesCommon FilesRoxio SharedDLLShared;C:Program FilesCommon FilesRoxio Shared10.0DLLShared;C:Program FilesJavajdk1.6.0_13lib;c:usersrickgwtantbin;C:Program FilesJavajdk1.6.0_13bin;C:androidandroid-sdk-windows-1.6_r1tools;C:Program FilesPalmSDKbin;C:Program FilesPalmSDKbinnovacom;C:Program FilesCalibre2;C:Program FilesPalmSDKbin;C:Program FilesPalmSDKbinnovacom
14:56:58: Checking that is in PATH...
14:56:58: in PATH.
14:56:58: Loading avformat from avformat-52.dll
14:56:58: Error: Failed to load shared library 'avformat-52.dll' (error 126: the specified module could not be found.)
14:56:58: Loading avutil from avutil-50.dll
14:56:58: Error: Failed to load shared library 'avutil-50.dll' (error 126: the specified module could not be found.)
14:56:58: Loading avcodec from avcodec-52.dll
14:56:58: Error: Failed to load shared library 'avcodec-52.dll' (error 126: the specified module could not be found.)
14:56:58: Looking for FFmpeg libraries...
14:56:58: mLibAVFormatPath is not empty, = C:Program FilesFFmpeg for Audacityavformat-52.dll
14:57:08: User-specified path = C:Program FilesFFmpeg for Audacityavformat-52.dll
14:57:08: User-specified file exists. Success.
14:57:08: Trying to load FFmpeg libraries
14:57:08: mLibAVFormatPath is not empty, = C:Program FilesFFmpeg for Audacityavformat-52.dll. Loading from it.
14:57:08: Looking up PATH...
14:57:08: PATH = C:Program FilesSafari;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:Program FilesCommon FilesRoxio SharedDLLShared;C:Program FilesCommon FilesRoxio Shared10.0DLLShared;C:Program FilesJavajdk1.6.0_13lib;c:usersrickgwtantbin;C:Program FilesJavajdk1.6.0_13bin;C:androidandroid-sdk-windows-1.6_r1tools;C:Program FilesPalmSDKbin;C:Program FilesPalmSDKbinnovacom;C:Program FilesCalibre2;C:Program FilesPalmSDKbin;C:Program FilesPalmSDKbinnovacom
14:57:08: Checking that C:Program FilesFFmpeg for Audacity is in PATH...
14:57:08: not in PATH!
14:57:08: Appending ;C:Program FilesFFmpeg for Audacity ...
14:57:08: Loading avformat from C:Program FilesFFmpeg for Audacityavformat-52.dll
14:57:09: Error: Failed to load shared library 'C:Program FilesFFmpeg for Audacityavformat-52.dll' (error 1114: a dynamic link library (DLL) initialization routine failed.)
14:57:09: Loading avutil from C:Program FilesFFmpeg for Audacityavutil-50.dll
14:57:09: Loading avcodec from C:Program FilesFFmpeg for Audacityavcodec-52.dll
14:57:09: Error: Failed to load shared library 'C:Program FilesFFmpeg for Audacityavcodec-52.dll' (error 1114: a dynamic link library (DLL) initialization routine failed.)
14:57:09: Returning PATH to normal...
14:57:09: Failed to load FFmpeg libs
14:57:09: Trying to load from default path C:Program FilesFFmpeg for Audacityavformat-52.dll.
14:57:09: Looking up PATH...
14:57:09: PATH = C:Program FilesSafari;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:Program FilesCommon FilesRoxio SharedDLLShared;C:Program FilesCommon FilesRoxio Shared10.0DLLShared;C:Program FilesJavajdk1.6.0_13lib;c:usersrickgwtantbin;C:Program FilesJavajdk1.6.0_13bin;C:androidandroid-sdk-windows-1.6_r1tools;C:Program FilesPalmSDKbin;C:Program FilesPalmSDKbinnovacom;C:Program FilesCalibre2;C:Program FilesPalmSDKbin;C:Program FilesPalmSDKbinnovacom
14:57:09: Checking that C:Program FilesFFmpeg for Audacity is in PATH...
14:57:09: not in PATH!
14:57:09: Appending ;C:Program FilesFFmpeg for Audacity ...
14:57:09: Loading avformat from C:Program FilesFFmpeg for Audacityavformat-52.dll
14:57:10: Error: Failed to load shared library 'C:Program FilesFFmpeg for Audacityavcodec-52.dll' (error 1114: a dynamic link library (DLL) initialization routine failed.)
14:57:11: Error: Failed to load shared library 'C:Program FilesFFmpeg for Audacityavformat-52.dll' (error 1114: a dynamic link library (DLL) initialization routine failed.)
14:57:11: Returning PATH to normal...
14:57:11: Failed to load FFmpeg libs
14:57:11: Trying to load from system paths. File name is avformat-52.dll
14:57:11: Looking up PATH...
14:57:11: PATH = C:Program FilesSafari;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:Program FilesCommon FilesRoxio SharedDLLShared;C:Program FilesCommon FilesRoxio Shared10.0DLLShared;C:Program FilesJavajdk1.6.0_13lib;c:usersrickgwtantbin;C:Program FilesJavajdk1.6.0_13bin;C:androidandroid-sdk-windows-1.6_r1tools;C:Program FilesPalmSDKbin;C:Program FilesPalmSDKbinnovacom;C:Program FilesCalibre2;C:Program FilesPalmSDKbin;C:Program FilesPalmSDKbinnovacom
14:57:11: Checking that is in PATH...
14:57:11: in PATH.
14:57:11: Loading avformat from avformat-52.dll
14:57:11: Error: Failed to load shared library 'avformat-52.dll' (error 126: the specified module could not be found.)
14:57:11: Loading avutil from avutil-50.dll
14:57:11: Error: Failed to load shared library 'avutil-50.dll' (error 126: the specified module could not be found.)
14:57:11: Loading avcodec from avcodec-52.dll
14:57:11: Error: Failed to load shared library 'avcodec-52.dll' (error 126: the specified module could not be found.)
14:56:58: in PATH.
14:57:11: in PATH.
rboatright
Note also please that I have re-downloaded the ffmpeg dll now about a half-dozen times. I don't THINK that I have a corrupt one.
RIck
RIck
- Quality Assurance
Thanks for the log. Unfortunately the ffmpeg.dlls can conflict on load with those of other instances of ffmpeg on your computer. We've never really got to the bottom of it, and the developer who introduced the ffmpeg feature is not currently active on the project. I note however you have lots of software and SDKs in your Path environment variable which could contain conflicting dll's.rboatright wrote:Here is the log per your request
There are several things you could try:
- If you don't need FFmpeg in other applications, search your computer for "av*.dll" (without quotes). That command finds any dll files whose name starts with "av". The FFmpeg files will be called avcodec*, avdevice*, avformat* or avutil* and you can delete them (except those in C:Program FilesFFmpeg for Audacity).
- If you do need FFmpeg in other applications, you could try actually adding C:Program FilesFFmpeg for Audacity to your Path and restart the computer, or open C:Program FilesFFmpeg for Audacity, copy all the contents and paste them into the "Modules" folder which should be inside your Audacity installation folder. When you restart Audacity after the paste, use the "Locate..." button in the Libraries Preferences to look for "avformat-52.dll" in the "Modules" folder. Both the above have been reported to work. I am not sure why the "Modules" directory might work except that it would be the working directory for recent Audacity Betas.
- Use FFmpeg at the command line instead to convert to or from your chosen format. The FFmpeg user docs are here
- If you are only interested in exporting from Audacity to FFmpeg formats, you can try the command line exporter in Audacity to send a command directly to ffmpeg.exe. This does not require Audacity to load the FFmpeg dll's through Preferences.
- I would rename C:Program FilesFFmpeg for Audacity to something else for example
C:Program FilesFFmpeg_Audacity
- Launch Audacity, leave Preferences alone then click File > Export when you are ready
- Choose (external program) in the "Save as type" then click "Options"
- In the "Command" box, enter the path to ffmpeg.exe enclosed in quotes, followed by -i and - "%f" , for example- You can add other commands with normal syntaxCode: Select all
"C:Program FilesFFmpeg_Audacityffmpeg.exe" -i - "%f"
- Click OK, then type the file name and extension such as "myfile.ac3" then Save
