Pasting text into "Edit the Metadata Tags" box
pswinbank
Post by pswinbank » Sat Jan 08, 2011 11:08 am
I do not understand why Audacity will not let me paste text I've copied from Windows Notepad into the "Comments" box of the "Edit the Metadata Tags" box in Edit?
Advice would be gratefully appreciated.
Peter
Irish
Forum Crew
Re: Pasting text into "Edit the Metadata Tags" box
Post by Irish » Sat Jan 08, 2011 10:53 pm
When you click in the comments box (or any other box) in the editor, the box is highlighted with a dark border, and you can start typing text but, as you say, you can't paste text from the clipboard.
If you click again in the box, the highlighting disappears, and a cursor appears in the box. Now you can paste your text.
Before you ask, I don't know why it is designed this way.
POL
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
pswinbank
Post by pswinbank » Sun Jan 09, 2011 7:14 pm
POL, brilliant, thanks. I'll try this.
This function is very important to me.
Thanks again for your interest and advice.
Peter
