digiday wrote:is there an encoder that allows Audacity to export to MIDI format?
Audacity's MIDI support is very limited. Currently the only thing that Audacity can do with MIDI files is to display them as a track.
MIDI is not audio. You cannot directly "convert" audio to MIDI - it's not like converting TV to DVD, it's more like converting TV into a book.
MIDI is a set of control commands that tell MIDI equipment what to do, for example a MIDI file can contain "note data" that tells a synthesizer what notes to play.
http://en.wikipedia.org/wiki/Musical_In ... _Interface
digiday wrote: I want to send some of my family some things that I've produced with visuals and sound in an email if possible...
There's a number of difficulties with that. While it is quite easy to insert background music using Outlook Express, and it will play if opened in Outlook Express, this is quite a serious security vulnerability. If an e-mail can make your computer play audio files, it can probably make your computer do lots of other things, which could be very bad. Thunderbird closes this security hole by disallowing active, hidden and remote content by default. Because of this it's pretty pointless for Thunderbird to provide background sounds as background sounds should not play without the recipient specifically playing the embedded audio.
Possibly a better way to achieve the result would be to make a web page that contains the message and the embedded background music, then send a link to that web page in your e-mail.
digiday wrote:I'm trying to avoid installing IncrediMail,
Good idea.
