The final volume level trouble.
zby
Post by zby » Thu Jan 06, 2011 12:03 pm
Hey to all.
SW: Audacity-1.3.12 on Fedora 13 via the jack server.
HW: Compaq Evo d510, IP4 2GHz, 1.2GB RAM, 80GB 7200rpm HDD, Intel AC ‘97 integrated SND card.
I use audacity to mix wav data dumped from midi tracks to create a song prototype to jam/improvise into ... The HW handles recording well as far as the even input data stream flow :) Other things may come to discuss later.
One thing troubles me now. After recording and saving the project I edit the tracks. That is (in 90%) increasing the volume of drums to the limit and the rest of the tracks' volume to my liking... Need to say that I do not allow clipping on any of the tracks.
Once I'm done exporting the project to an mp3 or an ogg file I found that the final volume level is quite lower than other mp3s from a different resource (a CD for instance).
The question is:
1. Why is it so?
2. What may be the limiting HW or SW part in my PC?
bgravato
Re: The final volume level trouble.
Post by bgravato » Thu Jan 06, 2011 6:40 pm
You might be looking for dynamic compression. What a dynamic compressor does is to amplify the quieter parts while keeping the louder parts below clipping. In other words it narrows the volume gap between loud and quiet parts. Audacity has a dynamic compressor in the effects menu. There are more plugins you can download and add to audacity. Chris compressor is highly regarded among the users of this forum. It is downloadable as a plugin for audacity. If you search the forum you'll find a lot of threads about it.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
Post by steve » Fri Jan 07, 2011 2:33 am
Most CDs are artificially loud - see here: http://en.wikipedia.org/wiki/Loudness_war
--Rikke--
Post by --Rikke-- » Tue Aug 02, 2011 11:27 pm
Hi there,
I have the problem that after I export to mp3 the sound goes crazy, turning my speak up and down.
Can I change the settings? Would it help to download the Chris compressor? Or could it be me, that have made a mistake by using "normalizer"???
I hope you can help asap.
Thank you very much
Trebor
Post by Trebor » Wed Aug 03, 2011 12:11 am
--Rikke-- wrote: I have the problem that after I export to mp3 the sound goes crazy
If the sound becomes only becomes "crazy" after exporting as MP3 then that could be due to the MP3 bit-rate being set too low, see here ... http://forum.audacityteam.org/viewtopic ... 28&t=41915&
Antomi
Post by Antomi » Wed Aug 07, 2013 3:15 pm
Hello,
I have the same problem.
I normalized the file (-0.5 dB) and export it.
When I open it again, the volume level is reduced to -25 dB.
This happens with all formats (mp3, wav, etc.)
I really don't understand, what is going on.
Any ideas.
Thanks for the helpö.
Best
Antomi
Post by steve » Wed Aug 07, 2013 3:23 pm
Check that the track Gain slider is set to zero before you export http://manual.audacityteam.org/o/man/au ... .html#gain
Antomi
Post by Antomi » Wed Aug 07, 2013 5:26 pm
Steve,
thank you!
You saved my day.
Best
Antomi
