Can't use "z" in labels; can use "Z" ?!
hellosailor
Post by hellosailor » Sun Jun 22, 2008 8:01 pm
I'm using the stable release (not the beta) of Audacity under Vista Ultimate SP1 and (WOW!) finally getting the hang of it.
Except, when I try to type a lowercase "z" in a label, nothing appears. No space, no null, nothing. If I type a shift+Z (uppercase) it is typed into the label just fine!
Nothing wrong with the keyboard, it is able to make lowercase zzzz's all over the place.
Is this a special gremlin, os something anyone else has met before?
jan.kolar
Re: Can't use "z" in labels; can use "Z" ?!
Post by jan.kolar » Sun Jun 22, 2008 11:12 pm
Yes I remember that reported. And trying with my 1.2.6: yes it does exactly what you say.
I would call it a bug but gremlin is very nice, too.
(Thanks for introducing me to the automagical disneyland on the other topis.)
Jan
waxcylinder
Post by waxcylinder » Mon Jun 23, 2008 8:25 am
It's a "feature" - it's because the z is being usded by Audacity as a keyboard shortcut.
I don't think this behaviour carries forward to the 1.3.x Beta versions.
I just used to workaround it in 1.2 by using the uppercase Z in the labels and then editing the filenames and tags of the exported files.
hellosailor
Post by hellosailor » Fri Jul 04, 2008 5:36 am
A feature? How nice. The author(s) have done a marvelous job and should I ever meet Saint Peter I'll put in a good word for them, but surely they might have considered JAZZ might be a relevant track title, and it might need to be in lower case?
Among the others I have hit in recent days.<G>
