no sound
deniz666uk
no sound
i have converted a track to mp3 but when i try to play it in windows 11 it plays but theres no sound
EliseRobinson
Re: no sound
Have you exported successfully before?
Also check silly little things like Windows Media volumes etc etc.
"Knowledge is knowing a tomato is a fruit. Wisdom is not putting it in a fruit salad."
deniz666uk
Re: no sound
yes i have a while ago i have reinstalled audacity and started to transfer vinyl but a few problems have arose the first was the sound i checked windows like you said and found that i can only play windows if my ion usb is not plugged in... the next is i try to open my aup files that were made with audacity and its telling me the files cant be opened
Re: no sound
That's a common problem - the USB audio device in the ION TT takes over the Windows sound system for recording AND playback (even though the ON TT is not a playback device. The correct fix for this is to go into the Windows Control Panel, and in the "Audio Devices" section, set your normal sound card so that it is always used for playback. The alternative (easier?) way is to unplug the ION TT when you want to play back.deniz666uk wrote:and found that i can only play windows if my ion usb is not plugged in.
No don't do itdeniz666uk wrote:the next is i try to open my aup files that were made with audacity
Do they play in any other media player? Try Foobar2000 (excellent free audio player - does not look great, but is about the best audio player available for playing audio files and is also useful for converting audio files from one format to another).deniz666uk wrote:i have converted a track to mp3 but when i try to play it in windows 11 it plays but theres no sound
Cheryllion
Re: no sound
"That's a common problem - the USB audio device in the ION TT takes over the Windows sound system for recording AND playback (even though the ON TT is not a playback device. The correct fix for this is to go into the Windows Control Panel, and in the "Audio Devices" section, set your normal sound card so that it is always used for playback. The alternative (easier?) way is to unplug the ION TT when you want to play back."
But what good does that do when you need the ION TT to work? I have this same problem. It looks like audacity is working, but I want to hear what I'm playing while it is playing. It's worse than before -- at least in the past I could open audacity and turn on the ION, then make my recordings. Then I'd close everything and all the sound would be gone from my computer. So I would have to unplug the ION, and restart my computer to get sound. It is really stupid and annoying. It is probably a simple setting, but I don't know how to change it. I use Windows Vista if that helps. Thank you!
williamkidd
Re: no sound
Hopefully this will answer the Ion turntable questions.
Go to message #9 at this address: http://forums.ion-audio.com/showthread.php?t=365 (it should be the No sound on Vista machine thread)
For a little more step-by-step on the configuration go to Step 2 here: http://computershopper.com/howto/how-to ... p3s-200706 (after reading the above message, of course)
In a similar vein (while trying to stay on topic), I found a quirk on one of my Vista machines that has a Creative X-Fi sound card. I exited a program and found that I had no sound virtually anywhere else. Media player played sound but nothing else did. I ended up having to switch my sound card from game mode to entertainment mode and it fixed the problem where nothing else would, including a shutdown and restart. I still am not quite sure why this happened but it worked.
For those of you experiencing this issue with the Ion please let us know if this helped or not. Good luck.
WK
I would be remiss if I didn't add these links to other helpful Audacity pages:
http://audacityteam.org/wiki/index.php? ... _Home_Page
http://audacityteam.org/wiki/index.php?title=Tutorials
http://audacityteam.org/wiki/index.php?title=Tips
WK
