Recording from Crosley turntable
Did you buy a new mixer? Do you need advice? Post here.
Micki
Post by Micki » Fri Dec 31, 2010 8:40 pm
I am trying to record from a Crosley turnbtable, USB connected. It doesn't appear to be detectiong the input device. At least in doesn't appear on the recording device list.
Trebor
Re: Recording from Crosley turntable
Post by Trebor » Fri Dec 31, 2010 9:16 pm
Micki wrote:... doesn't appear on the recording device list.
It may be hidden, if so can be made to appear on the list, see ... http://forum.audacityteam.org/viewtopic ... 26#p119326
bgravato
Post by bgravato » Sat Jan 01, 2011 6:47 am
What's your operating system? Windows? MacOS-X? Linux? (which version?)
USB devices need to be connected to the computer before opening audacity. If you connect it while audacity is running you need to quit audacity and start it again.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
Micki
Post by Micki » Thu Jan 06, 2011 7:03 pm
Problem is resolved! Thank you!
