Cut Function
douglas
Cut Function
Post by douglas » Thu Jun 12, 2008 5:41 pm
I'm running a Mac OS X version 10.4 and I can load an mp3 file on to the audacity editor and play the clip. Unfortunately, after darkening the area I want to edit, I cannot cut the section. Does anyone have any ideas? After hitting "edit" the cut area is not darkened, so I can't access it.
Re: Cut Function
Post by kozikowski » Fri Jun 13, 2008 1:23 am
How much will you bet that you actually got an MP3 file? If you didn't, Audacity tools will not work.
If you download the short Piano Trill from here and try to cut it...
http://www.kozco.com/tech/soundtests.html
...do all the tools suddenly start to work?
