uploading from minidisc
deniz666uk
Post by deniz666uk » Wed Jun 11, 2008 11:25 pm
i am uploading from a minidisc to pc using audacity i have set it up cable to minidisc headphone and then to line in. when i record i can hear the music through audacity but when i play it back there is no noise its like it wasnt being recorded in the first place now my settings i assume are correct cause i am also tranfering vinyl using an ion turntable and not having any problems can someone help please
waxcylinder
Re: uploading from minidisc
Post by waxcylinder » Thu Jun 12, 2008 9:53 am
Is your ION one of the ones with a 1/8" mini-jack input? I so, are you plugging your minidisc in via that input. Try it with the ION turne d on and then off - I can't remember which way it worked on my ION.
I got better transfers when I switched to using an external soundcard (Edirol UA-1EX) witg digital input& output - this enabled direct digital transfers and hence no addiotional noise introduced by DAC=>ADC conversions.
deniz666uk
Post by deniz666uk » Thu Jun 12, 2008 1:07 pm
yes mine does but i didnt do it through there i did it straight to my pc but i just tried it your way and nothing
waxcylinder
Post by waxcylinder » Thu Jun 12, 2008 1:12 pm
The only difference I can see in my way using the ION is that I used the RCA outputs from the back of my minidisc deck rather than the headphone socket.
Going via the lin-in on the PC should work too.
So I'm stumped.
deniz666uk
Post by deniz666uk » Tue Jun 17, 2008 11:54 am
thanx for taking the time to reply i tried also another forum and 1 reply but that didnt work neither so not sure what to do now
Post by steve » Tue Jun 17, 2008 11:46 pm
The BIG difference between the ION TT and the minidisk is that the minidisk is going throughyour sound card, the ION TT does not. The ION TT has its own "sound card" built in and just sends digital data into your computer via USB.
In order to record the minidisk through your sound card, disconnect the ION TT from the computer and reboot (this should not be essential, but it is the easiest way to be sure that your computer sound system has not set itself to use the USB input.
Plug in your minidisk player to the LIne input of your sound card and use the Windows Mixer (accessed through the speaker icon near the system clock, or through the control panel) to set the Recording Input to the Line Input. (note that there are usually different pages in the Mixer for Record and Playback).
Now open Audacity and check in "Edit > Preferences > Audio I/O" that your sound card is selected for record and playback (if not, change the settings so that it is and restart Audacity.
Now start playing a minidisk and click on the recording meter in Audacity - you should see the meter respond to the audio input. You will probably need to adjust the output level from your minidisk player and/or the record level in the Windows Mixer to get an appropriate record level.
waxcylinder
Post by waxcylinder » Wed Jun 18, 2008 9:11 am
It depends how he has it configured Steve.
Many of the ION's have a 1/8" minijack input to enable you to plug auxiliary devices (Tape, minidisc etc.) in via the ION and thus use the ION's soundcard and USB devices (hence my question to the poster above about how he was configuring).
Post by steve » Wed Jun 18, 2008 3:30 pm
waxcylinder wrote:hence my question to the poster above about how he was configuring
Yes I read that - he replied that he was going direct into the sound card (hence my response)
At the moment it sounds like there is no signal coming out of the minidisk player, but we'll have to wait to hear back from deniz666uk.
waxcylinder
Post by waxcylinder » Wed Jun 18, 2008 3:52 pm
Aahhh.....
but it should be easy enough to test the output of the MD with a pair of headphones ....
