File name saving problem
This section is now closed
Aussie4ever
Post by Aussie4ever » Sat Dec 18, 2010 5:37 pm
When I export my files to mp3 and include the numeral "1" in the file name, the file starts playing while I am trying to save it.
The files I save are all related to the calendar, thus, there are lots of ones in the dates.
Is there something I can do to stop the file from playing? Thank you
Audacity 1.2.5 Mac OS 10.6.5
billw58
Re: File name saving problem
Post by billw58 » Sat Dec 18, 2010 5:50 pm
Best solution - upgrade to 1.3.12. Especially with OS X 10.6.x you should not be using Audacity 1.2.5.
http://audacityteam.org/download/beta_mac
Quick and dirty solution - go to Audacity > Preferences, the Keyboard tab, and change/clear all the "unmodified" keyboard shortcuts.
What's happening is that "1" is the shortcut to play 1 second of the file. There is a bug in 1.2.5 where unmodified shortcut keys (such as r p z 1 etc.) play the shortcut instead of typing into the save dialog box.
-- Bill
Post by kozikowski » Sun Dec 19, 2010 3:58 am
And it's not the only problem. Audacity 1.2 can be profoundly unstable in Leopard or Snow Leopard.
