I am using an Intel Mac OSX. How do I burn a CD that will play in car, etc.?
I have created an Apple AIFF file and would like to export to the above.
I am recording off a USB turntable from 33 rpm vinyl.
Beginner: Export to universally usable format on CD
calsbusiness
Re: Beginner: Export to universally usable format on CD
Open your music in iTunes. Create a new PlayList and pull your music to the playlist. One of the iTunes options is to burn the playlist to a CD.
This will produce a standard Music CD that will play in your car, truck, or mobile home.
