Can't record using iTTUSB
I am using Windows XP and have the Ion iTTUSB. I ran the CD to install the program and now I cannot record any records because the software does not give me an option on the "Mixer Bar" to select "Line In". Any help would be greatly appreciated.
waxcylinder
Re: Can't record using iTTUSB
You shouldn't need the mixer bar to select the input option. When you plug in a USB device like that Audacity recognizes that there is only one valid soundpath (The USB one) and disables the input selector. The ION manual used to be erroneous in this matter - and it looks like it still is.
The other problem you are likely to encounter is the the USB TT will take over the sound output - and as it doesn't have amp/speakers you won't get any sound - you will need to set Audacity and Windows to target the sound otput on your PCs onboard soundcard.
