massive noise on tracks, unpredictable
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
omegafold
Post by omegafold » Sat Dec 11, 2010 8:28 am
I have major STATIC not like background static, but like there would be a speaker wire going out or something...
now it will come and go with new tracks in recording off soundcard's stereo mix. You can't tell when it will be there and not. You have to record a whole track and then see if it's good.
I just clicked 'remove all tracks' option and it recorded fine in a test, but as soon as I tried to record again, bam!, major static is back.
it's killing me. help.
Once I slid the volume control up and down and that fixed it.
Usually closing the program or restarting does nothing.
I'm stuck. Don't have any idea what is causing the problem.
Re: massive noise on tracks, unpredictable
Post by steve » Sat Dec 11, 2010 9:44 am
Are you using a USB sound card (or similar device)?
bgravato
Operating System: Linux Debian
Post by bgravato » Tue Dec 14, 2010 10:54 pm
What's your recording source? Does that only happen with stereo mix?
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
db113
Post by db113 » Thu Dec 30, 2010 12:41 am
I am experiencing the same sort of problem.
I am attempting to record from my cassette player to the computer.
I monitor the song as its recorded and it sounds fine. When I play it back it has periods of a few seconds where it sounds as though the signal is being bounced or lost momentarily. It occurs in the first ten seconds of the song and then corrects for several seconds and then it might recur or it might not. I have recorded complete songs without the problem but it seems to be occuring more frequently. Im using 1.3.12 Beta.
Any suggestions.
Post by steve » Thu Dec 30, 2010 12:51 am
db113 wrote:I am experiencing the same sort of problem.
Not sure what you mean "bounced or lost" - that doesn't sound like the same sort of problem as "massive noise on tracks".
Could you clarify what you mean.
Also, it it a USB cassette player - if not, how is the cassette player connected to the computer?
Is it a laptop computer?
Which version of Windows?
db113
Post by db113 » Thu Dec 30, 2010 1:26 am
Windows XP.
The cassette player is a Yamaha K-720 with stereo outputs on the back and being fed into the computer through the "Pink" mic input on front of a HP desktop computer.
The sound I described as a bounce is as though the signal is being interrupted like there is a short in the cord for a few seconds and a "noise" is created by the bouncing effect. There does not appear to be a short in the cord.
I tried the same songs with the 1.2 version of Audacity and is was better but still some mild defect.
I closed all other programs running on the computer.
bgravato
Post by bgravato » Thu Dec 30, 2010 2:40 am
db113 wrote:Windows XP.
Pink mic input is designed for mic level signals not line level signals...
Mic level signal are very tiny signals which need a lot of amplification. Line level signals (such as the output of your cassette player) have a greater amplitude and usually connecting it to a mic input doesn't produce good results...
If your laptop doesn't have a line input (blue one), consider buying an external usb device such as the behringer uca-202. It's cheap and highly rated among the users of this forum.
Post by steve » Thu Dec 30, 2010 2:41 am
The pink input is for a microphone. It is not suitable for a line level signal such as the output from a cassette player.
Look for a light blue input socket.
[Edit] You must have posted just as I hit the post button bgravato :)
bgravato
Post by bgravato » Thu Dec 30, 2010 2:44 am
steve wrote:[Edit] You must have posted just as I hit the post button bgravato :)
Probably, but I got mine first so I win the candy! :P
db113
Post by db113 » Thu Dec 30, 2010 4:07 am
Thanks guys for the help.
I found a blue input in the back of the computer and I get sound through the computer speakers. Sounds good.
But, I dont get any action in Audacity. How do I configure Audacity to find the music. I dont see a "blue" input option. I see green and black offered but no blue.
Im getting close I think.
