Cannot change preferences to stereo recording
I have searched the forums and can't find an answer for this. I'm running Audacity 1.3.12 and Mac OS X 10.5.8. I go to System Preferences and choose my recording device, which is MXL Studio 1 USB. Then I open Audacity and go to preferences to select my USB. But it will not allow me to choose stereo recording. Only mono. Help! Thank you.
billw58
Re: Cannot change preferences to stereo recording
That would be because the XML Studio 1 USB is a mono USB microphone. Why do you want to record a mono microphone in stereo?spinnerj wrote:I go to System Preferences and choose my recording device, which is MXL Studio 1 USB. Then I open Audacity and go to preferences to select my USB. But it will not allow me to choose stereo recording. Only mono.
-- Bill
Well, that is stupid of me. Thanks.
billw58
Not at all. Many people believe they need to record their microphone (narration) in stereo in order to mix with a stereo music track. That, of course, is not the case since Audacity plays back a mono track to both left and right stereo outputs equally, resulting in the mono track appearing in the "centre" of the stereo image.spinnerj wrote:Well, that is stupid of me. Thanks.
However, if your project consists exclusively of mono tracks and you want to export a stereo file, you need to include an empty stereo track in you project - this will force Audacity to export a stereo file. Also, panning any of the mono tracks off centre will also result in the export of a stereo file, without the need to add an empty stereo track.
-- Bill
That's excellent advice about the empty stereo track. I really appreciate this. Thank you so much.
