How do I get a track from project into another
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
billw58
Re: How do I get a track from project into another
Post by billw58 » Tue Dec 07, 2010 3:32 am
Well then I'm stumped. You still haven't told us what computer and operating system you are using.
-- Bill
cfmoore1
Post by cfmoore1 » Tue Dec 07, 2010 6:38 pm
I just found I can successfully past other tracks (also a few short clips with 0 time line on either side) from the backup to the project keeping same distance between clips and total time
Tried going with the same track from the current project to the back up but getting the same shortened time period and less space between clips.
Chalk this up as a digital hiccup
mithunsingh
Post by mithunsingh » Fri Dec 10, 2010 1:28 pm
This process is a bit cumbersome if you are making frequent changes to both projects. It may make sense to finalize one of the songs as much as possible and then import the finished one into the other project. This will save you a lot of back and forth later on.
Thank you
