This section is now closed
Audacity 1.2.x is now obsolete. Please use the
current Audacity 2.1.x version.
Mac 0S X 10.3 and earlier are no longer supported but you can download legacy versions of Audacity for those systems
HERE.
gabby
Post
by gabby » Sat Dec 04, 2010 3:36 am
i cant make the audacity to play a track with sound, simultaniously ,while i m recording another track with voice.... the thing is that the sound only comes out when i am singing and when i stop the voice it also stops the recording and the play function of the other track... i don t know why they seem to be conected to the same comand.. they are not individual and independent from eqach other...
please answer me i would be very greatfull if you do so.... thanks.....
gabby
Post
by kozikowski » Sat Dec 04, 2010 4:01 am
Two problems. You should install Audacity 1.3.12 from here...
...and stop using Audacity 1.2, although you don't have to uninstall it.
Then, drill down to Audacity > Preferences > Recording and turn off Voice Activated Recording. That should solve those two immediate problems.
gabby
Post
by gabby » Fri Dec 17, 2010 4:08 pm
thanks a lot... i would try this as soon as i get home.....today.
