How to have a booming voice like God with effects?
Strickalator
Re: How to have a booming voice like God with effects?
Post by Strickalator » Sun Dec 05, 2010 1:48 am
So what did you do there in that before and after to make it sound better? :?:
Post by kozikowski » Sun Dec 05, 2010 4:08 am
Here it is. Chorus effect.
Throw that in the mix. Whisk gently.
http://forum.audacityteam.org/viewtopic ... 26&t=27902
Trebor
Post by Trebor » Sun Dec 05, 2010 4:51 am
Strickalator wrote:So what did you do there in that before and after to make it sound better? :?:
The main thing was using a reverb which mixes a little of left with right and vice versa, which gives a wide (3D) stereo effect.
ANWIDA reverb and Freeverb* (both free) do that L-R crossover thing, (whether you like it or not), Gverb doesn’t crossover, (which isn't necessarily a bad thing).
As I mentioned I also boosted the higher frequencies which improves intelligibility, (but also makes any hiss noise more obvious).
[* apparently there are Freeverb2 and Freeverb3, the one I've got is "Dreampoint Freeverb", no number.
Be careful where you download from: preferably only download from the manufacturer/creator].
Post by kozikowski » Sun Dec 05, 2010 7:25 am
It's easy for reverberation effects to make the voice muddy. You might want to put the clean voice on one track and the effect voice on a lower one. Use the Envelope tool to go between them until you get what you want. You can do that with the other tools as well.
I still think you can get a very otherworldly effect by just pitch shifting one piano note in addition to the other tools.
