Remix stereo left channel vocals right channel instrum
cfmoore1
Post by cfmoore1 » Thu Dec 02, 2010 8:51 pm
Suggestions for remixing the stereo version of "Please Please Me", by the Beatles which is
Left Channel - only instruments
Right Channel - vocals with 6 guitar segments (2-3 sec each and 1 at 1 sec) and 4 harmonica segments (sec 7, 3.5, 2.5,3,5). The instruments are not mixed with the vocals and can be separated. Vocals can be separated into four types, Lennon only, McCartney/Harrison, Harrison (1), and all three together
End result stereo with vocals on both channels with the vocals centered.
Trebor
Re: Remix stereo left channel vocals right channel instrum
Post by Trebor » Fri Dec 03, 2010 4:23 am
cfmoore1 wrote:Suggestions for remixing the stereo version of "Please Please Me" ...
You could make a copy of the right channel, re-label this copy as left, then invert it ...
re-lable copy of right channel as left.jpg (38.65 KiB) Viewed 1106 times
Re-label original left track as mono so the backing (drums+bass) is also centered.
The result will be dual mono rather than true stereo, but the vocals and backing will be centred rather than only coming from one side.
A pseudo-stereo effect can be created from dual mono by applying different equalization to each channel and/or putting the channels slightly out of sync.
Attached is proof of concept, (from rough Youtube version ... http://www.youtube.com/watch?v=6vZLVJwXP-U) ...
