Thanks for the continuing help.
@bgravato: What USB Device would you suggest? I really only need stereo input, but I've noticed those are hard to come by. Obviously it would also need to be compatible with linux and audacity.
No Overdub with Rock Band USB Mic
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Re: No Overdub with Rock Band USB Mic
If you only need one stereo line-level input you have the inexpensive (and often recommended here on the forums) behringer uca-202. I don't have one but I believe it works fine in Linux, Steve can confirm it.lexen wrote:Thanks for the continuing help.
If you need mic input and preamp with phantom power I recommend the ART USB Dual Pre. Works out of the box in linux and with audacity. I've written a review here: http://forum.audacityteam.org/viewtopic ... 27&t=27862
Also check this thread: http://forum.audacityteam.org/viewtopic.php?f=27&t=9477
Regarding internal soundcards... I have an Asus Xonar Essence STX, it works well in linux, some features are not available on linux, but more have been added at each new alsa release. I use it mainly for listening to music on headphones (the headphone output is really good and can drive high impedance headphones). It has a shared line-in/mic-in (software selectable). I rarely used it. I did a brief test on the line-in and it seemed to be pretty much noise free. I haven't tested the mic input. I highly recommend it if you like to listen to music on high-end headphones from the computer. Otherwise there might be cheaper solutions with less features that will suit your needs better.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
Yes the UCA 202 works well on Linux - I use it to connect a small mixing desk to my laptop, and the output to an amplifier.bgravato wrote: behringer uca-202. I don't have one but I believe it works fine in Linux, Steve can confirm it.
There's a review of this and other sound cards in this topic: http://forum.audacityteam.org/viewtopic.php?f=27&t=9477
Thanks guys! I'll check those out.
