Thank you, that helps! I also gave Memory Usage priority to System Chache, increased Virtual RAM and turned on "Play and/or record using RAM (useful for slow drives) so now audio is chached in memory not in my old drivesteve wrote:Turn off Unnecessary Applications
Defrag Your Hard Drive
Give priority to "Background Services" ( Start > Control Panel > System > Advanced tab. Click the Performance "Settings" button and select the Advanced tab. Under Processor Scheduling, select "Background services" )
Problem while playing a track
anton_taskov
Re: Problem while playing a track
That may help in the short term. Computer memory is the sprinter. Blistering fast performance for a short time. Disk Drive is the long-haul performer. That's where you need to put the two-hour show you decided to make of crickets chirping."Play and/or record using RAM (useful for slow drives) so now audio is chached in memory not in my old drive
Internally, Audacity works at really high quality and takes up a lot of room. Particularly on an older machise, you're going to run out of hardware memory in very short order -- worse, you're going to find out all about that ratty stick of memory that few programs use -- until now.
Even if you do use the hard drive for live capture, there are limitations to that, too. "I tried to record BBC-1 for nine hours and my computer crashed." How full, fragmented, or slow is your hard drive?
Live audio (or video) production retires many computers.
anton_taskov
That's what I need - 3-4 minutes of playing.kozikowski wrote:That may help in the short term.
It's 298 GB Total/295 GB Free, unfragmented (Disk Defragmenter says that).kozikowski wrote:How full, fragmented, or slow is your hard drive?
No, I use it for a vinyl cutter (homemadekozikowski wrote:Live audio (or video) production retires many computers.
OK, I'll disable it and check out the results.
