echoing sound
ecmiles
echoing sound
Post by ecmiles » Sat Nov 27, 2010 8:45 pm
this is the first time i have used this program. i brought a clip in just to try the noise reduction, now my entire sound system sounds like it is echoing. all my video files, music files, etc. i did not save anything and am unable to undo whatever was done. how do i get my sound back to normal?
Re: echoing sound
Post by steve » Sat Nov 27, 2010 8:53 pm
Close Audacity and reboot your computer and your sound system should return to normal.
Which version of Windows are you using?
Which version of Audacity are you using?
What sort of sound card do you have?
Is the computer a laptop or desktop?
