will not play
will not play
when i press the play button it depresses and the green bar pops up at the beginning of the track but it does not move. i can still record i just cant play. ok i just tried playing itunes and internet videos and none of them will play also.
Re: will not play
Audacity doesn't support iTunes or video files, so that's why they won't play. Are you getting the same problem with WAVs and MP3s?throutt wrote:ok i just tried playing itunes and internet videos and none of them will play also.
Re: will not play
no i wasnt talking about those things in audacity. my output just isnt working for anything
Re: will not play
You are not giving enough information.
What is your setup, and what are you doing (step by step).
It could be that you've plugged in a USB mic and it has hijacked your audio system, or any of a thousand other things.
Re: will not play
i got tired of messing with my comp, so i just restarted and problem solved, ill post if it acts up again.
Re: will not play
ok, now that that problems solved another one just had to pop up to make it impossible to work. now it wont pick up the input signal, i press record and that little blue line doesn't expand at all.
Re: will not play
Try to reset everything to the previous values, when it was recording.
Perhaps use http://audacityteam.org/forum/viewtopic ... 870#p17870 as a checklist.
Do not forget to restart audacity if you change Prefs>AudioIO. Perhaps restart windows again.
And give more details if problem persists. Can you still record by Sound Recorder of Windows?
