can't change playback speed
This section is now closed
zina
Post by zina » Tue Nov 23, 2010 6:26 pm
I loaded 1.2 and that went well, then I tried to play a song (about 10 minutes long) on audacity, but it played the song in about 1.5 seconds, just a high-pitched garble. I have looked in the help stuff and on-line, but I cannot figure out how to slow down the playback. I cannot even find the topic listed anywhere. What am I doing wrong? Thanks.
waxcylinder
Re: can't change playback speed
Post by waxcylinder » Tue Nov 23, 2010 6:29 pm
You are almost certainly trying to import a file type that Audacity does not support. Audacity Supports WAV, MP3, OGG and FLAC & MP2 in 1.3.
The screech is Audacity 1.2's inelegant way of telling you that it can't handle the file type you've given it - in 1.3.x a more appropriate and informative error message appears.
If this is the case you have two basic options:
1. find and use some converter software to convert your file to a type that Audacity supports
2. play the file in any music software that supports that particular file format and record it in Audacity.
steve wrote:There's a free program called SUPER by erightsoft that can convert most media file types. If you can convert the files to WAV files that should fix the problem.
Post by steve » Tue Nov 23, 2010 6:38 pm
With the assistance of "FFmpeg", Audacity 1.3.12 supports a lot more audio formats than the old 1.2.6 version.
http://manual.audacityteam.org/index.ph ... tallffmpeg
I think that SUPER is Windows only (and this is the Mac OS X forum).
You may be able to convert the files using iTunes.
waxcylinder
Post by waxcylinder » Tue Nov 23, 2010 6:45 pm
steve wrote:I think that SUPER is Windows only (and this is the Mac OS X forum).
Oops, yes I hadn't noticed properly this was the MAC section :oops:
In which case I'm guessing the the posters file is in Apple's AAC format - and as Steve says you can ue iTunes to convert that to WAV for Audacity import.
