Is there a simpler way to import a track?
Djard
Post by Djard » Mon Nov 22, 2010 7:07 pm
I tried to import an MP3 file into an existing project as an additional track, but Audacity opened up a new page. So I minimized the GUI then dragged and dropped the file into my project from Win Explorer. Is there an easier way to perform this from Audacity's menu? Also, is there a way to export just one track from a multi-track project?
billw58
Re: Is there a simpler way to import a track?
Post by billw58 » Mon Nov 22, 2010 7:21 pm
Use File > Import > Audio to import an MP3 into an existing project.
To export just one track, select the track then do File > Export Selection.
-- Bill
Djard
Post by Djard » Tue Nov 23, 2010 12:11 am
Thanks. That worked. I can't believe I overlooked it (well, yes I can).
Post by steve » Tue Nov 23, 2010 1:30 am
You should also be able to import a track by dragging the file onto the open Audacity window.
