New user : In the option Edit/Preferences/Audio I/O/Recording, the only selections available are :-
Microsoft Sound Mapper – Input and Microphone (Conexant High Defin
The USB option is not displayed.
Why is this not appearing (includes 1.3 Beta)?
No USB option.
feethams_1883
Re: No USB option.
The USB device must be connected and recognised by Windows before you start Audacity.
If you have Audacity 1.2.6 and 1.3.12, I would recommend that you use Audacity 1.3.12 as it is generally more reliable and has a great many enhancements that are not available in the old 1.2.6 version. If you 1.3.x version is older than 1.3.12 you should update it (Look in "Help menu > About Audacity" for the version number).
feethams_1883
Re: No USB option.
Thank you : I’m using 1.3.12 and tried that and now get :-
Microsoft Sound Mapper – Input;
Headset Microphone (2-UAC3556B
Microphone (Conexant High Defin;
Line (2-UAC3556B
Is USB one of these?
Line (2-UAC3556B
Re: No USB option.
UAC3556B is a USB chip.
What is the actual device that you are wanting to record from?
("Conexant High Defin" is the computer's internal sound card)
feethams_1883
Re: No USB option.
A Bush USB turntable.
Re: No USB option.
<<<Line (2-UAC3556B>>>
I think I'd pick that one. Reset Audacity preferences and Quality to 44100, 16-bit, Stereo. Restart Audacity. Then go back into Windows Control Panels and make sure it's not trying to send your speaker sound back out to the turntable. That's another common complaint: I plugged my turntable in and now I can't hear anything.
