From your first post, taking a look at your alsamixer screenshot, looks like you're capturing sound from S/PDIF, I don't think that's where you want to capture sound from...
In capture mode (F4) of alsamixer, use the left/right arrow keys to highlight "Capture" then press spacebar. You should now see CAPTURE in red written above it. You can do the same for Capture 1 if the previous doesn't succeed.
Problem recording computer audio
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Re: Problem recording computer audio
I've already tried that, it didn't workbgravato wrote:From your first post, taking a look at your alsamixer screenshot, looks like you're capturing sound from S/PDIF, I don't think that's where you want to capture sound from...
