I am new to this and have spent many hours over the last three days trying to figure out my problem. Needless to say, I'm tired and very frustrated.
Here's the problem.
I have a cassette that needs to be converted to CD. I downloaded AUDACITY to my PC. I connected my tape player via the headphone jack and my input on the PC. I have get sound through the PC speakers when I push the record button. I see the green and red monitors and the blue wave will go up and down occasionally. (As the speaker's voice increases)
My problem is that when I go to play it back there is NO sound whatsoever. (I have the green bars that move back and forth though) I have tried to listen through just my computer and also burning a CD with no luck whatsoever.
Please can you help me? I've read and read the post and there aren't any listed that are like my problem. There are some that are close and I've checked the suggestions from them, but I still am having no luck in getting any playback.
When you answer, please list a detailed, step by step instructions since I am new to this and really don't know what I'm doing. I'm sure it is an easy problem to fix, I just don't know how.
Thanks so very much,
Valorie
No audio playback after I've recorded
Newandneedhelp
williamkidd
Re: No audio playback after I've recorded
I learned about Audacity through an article in Computer Shopper. It's a nice step by step guide to setting up and using Audacity. You can find the archived article at http://computershopper.com/howto/how-to ... p3s-200706. Let us know if this helps.
waxcylinder
You should find the Audacity wiki, tutorials and tips useful too:
http://audacityteam.org/wiki/index.php? ... _Home_Page
http://audacityteam.org/wiki/index.php?title=Tutorials
http://audacityteam.org/wiki/index.php?title=Tips
Cheryllion
I have this same problem -- when I use Audacity it seems to work fine, but as soon as I close it down all the sound is gone from my computer. I can still see mixers moving, so the sound is playing; it's just that nothing is there. I use the ION turntable, too, if that makes a difference. If I unplug all the sound equipment from my computer and restart I can usually get sound back, but that is ridiculous. It's probably just one easy setting that I need to fix but I can't find the answer on any audacity links.
Did you ever figure out the answer to this question? Because it looks like no one answered it for you, really. Thanks!!
Cheryl
Cheryl
williamkidd
Cheryllion,
Check out my post under "no sound" and let us know if this helps.
WK
I would be remiss if I didn't add these links to other helpful Audacity pages:
WK
Cheryllion
Thank you! That was very helpful.
