Gotta problem with space on hard disk, I guess this is the cause (only 2GB free). Tried to restore but the audacity file project has only a flat line instead of a wave form. The interesting thing is that the recording has some 55mb like it has the file but I cant open it?
Anyway, can I save my work or am did I lose my stuff permanently?
Crashed audacity 1.3.12 beta, cant recover the project
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Re: Crashed audacity 1.3.12 beta, cant recover the project
2GB should be enough...
What has 55mb?
What has 55mb?
The recording which was edited and exported. So I have this recovery version of the file and it is 500 MB in size, but when I open it I see only a flat line (some 55 min of audio). I have tried to export this file in a hope it would somehow work when exported to mp3 format. This file is 55 MB big, but it still has only a flat line instead of wave form. Loks like I have the file but instead of the recording I can see only a silent, flat line.
o
o
If it's a flat silent line on audacity, then it will still be all silent if you export it whatever the format is...
I'm afraid your show might be lost for good
As a good practice always save your show right after you finish recording it... It's also advisable to export as wav (or flac) as a backup.
Thanks,
it seems that for me it is not good enough to relay on auto saving, but I must always manually backup work in progress. It was literally the last click on the edited podcasts when the audacity crashed ( after a full day of working on it).
waxcylinder
Not just for you - it's something we all should do regularly (but many of us fail to). I certainly wouldn't rely on autosave for a full day's work with any s/w package - not just Audacty, the same goes for Word, Excel, Photoshop etc.smrki wrote:it seems that for me it is not good enough to relay on auto saving, but I must always manually backup work in progress. It was literally the last click on the edited podcasts when the audacity crashed ( after a full day of working on it).
If you do make intermediate saves during a day's work I would suggest storing them in (slightly) different filenames - that way you can always go back to an intermediate version. It's also seen as good practise to make a save or export a WAV (or both) immediately after raw capture and before editing.
