File size question.
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
clarkjo1
File size question.
Post by clarkjo1 » Mon Nov 08, 2010 2:33 am
After cutting, how do I save the file so the file size won't increase? My 7 meg file increased to 12 meg after cutting some audio out, and I want it to be no larger than 7 meg. Thanks. :)
billw58
Re: File size question.
Post by billw58 » Mon Nov 08, 2010 2:38 am
What format was the original file in (WAV, MP3, etc.)? How did you save the new copy? Did you do File > Export? Was the original file mono but you saved it in stereo?
-- Bill
aquamkd
Post by aquamkd » Wed Jan 19, 2011 12:30 am
I have experienced the same.I saved my file in stereo and its size was larger...
bgravato
Operating System: Linux Debian
Post by bgravato » Wed Jan 19, 2011 8:16 am
aquamkd wrote:I have experienced the same.I saved my file in stereo and its size was larger...
We need a little more info than that... What was the original format of the imported file? was it mono? 16 bits or 32 bits? did you export in the same bit depth?
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
clarkjo1
Post by clarkjo1 » Sun Jan 30, 2011 12:40 am
The original file was mono and wma. I did the import & export thing. How do I tell the bit size? Please help.
Thanks,
John
Post by kozikowski » Sun Jan 30, 2011 5:02 am
Windows Media is a highly compressed audio system. If you open a WMA file and do almost anything to it, it's going to get bigger, or if you leave it the same size, it may get damaged and sound funny. You loaded FFMpeg into Audacity, right? See if it will let you export a new WMA file and tune the compression so the sizes come out right. I'm trying this myself.
Post by kozikowski » Sun Jan 30, 2011 5:07 am
Yeah. Here it is. File > Export > WMA > Options > bitrate. Keep reducing the bitrate until the size comes out right. Audacity doesn't directly edit most files. It converts the music to an internal format and then you have to Export a whole new file.
