Can't locate plugin
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Can't locate plugin
I installed the Channel mixer plugin and also restarted Audacity. I have no idea how to access my plugin. There also seems to be a ton of plugins that I never installed and that I never use. How can I delete these?
- Attachments
- plugins.png (183.36 KiB) Viewed 805 times
Re: Can't locate plugin
How and where did you install your plugin to?
I solved the problem by deleting the Ladspa folder that contained the plugins. Not sure how those got installed. Maybe when I installed Ubuntu Studio?
Probably. You can check which package installed a certain file with the command dpkg. For example: or if the first return more than one result.
Code: Select all
dpkg -S filenameCode: Select all
dpkg -S /path/to/filename
