tried to compress classical music cd
system hung up
perhaps i need more memory
question 1
can the album be sliced into small pieces and done one at a time
using the same parameters each time
to get the same result
or will that affect the results
question 2
if there is any overlap in the smaller pieces compressed separately
will that affect the overlap
even if no make up gain was applied
question 3
if chris compressor wont work on this old machine and low ram
are there any alternatives other than copying the file
and finding a bigger pc ?
chris compressor failed
Re: chris compressor failed
Running out of RAM is the most likely cause.whomper wrote:perhaps i need more memory
Yes you can, but you need to be a bit careful about where the "joins" go.whomper wrote:question 1
If you can split the track during silent periods (between songs) then it will probably work fine.
Splitting a track while music is playing may cause a mismatch where the sections meet.
