Hello,
I compiled audacity 1.3.12. Then I tried to run it from the command line but it won't run. Below is the error message. Could someone show me or point me to a tutorial to get audacity started? Thanks (I just type ./audacity at the command prompt of my laptop, running Ubuntu 10.10. I don't have any special recording hardware or anything like that, just the laptop. I just want to see what the UI looks like first.) Do I need to disable certain things or do I need certain hardware to run this? Thanks again for the help.
-Long
[email protected]:~/audacity-1.3.12$ ./audacity
bt_audio_service_open: connect() failed: Connection refused (111)
Expression 'stream->capture.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 3847
*** glibc detected *** ./audacity: malloc(): memory corruption: 0xb6c012d8 ***
======= Backtrace: =========
/lib/libc.so.6(+0x6c501)[0x1466501]
/lib/libc.so.6(+0x6f2fc)[0x14692fc]
/lib/libc.so.6(__libc_malloc+0x63)[0x146af33]
/usr/lib/libwx_baseu-2.8.so.0(_ZN12wxStringBase11AllocBufferEj+0x54)[0x74da14]
/usr/lib/libwx_baseu-2.8.so.0(_ZN12wxStringBase8InitWithEPKwjj+0x4c)[0x74db0c]
/usr/lib/libwx_baseu-2.8.so.0(_ZNK12wxStringBase4findEPKwjj+0x34)[0x74f944]
/usr/lib/libwx_baseu-2.8.so.0(_ZN8wxString7ReplaceEPKwS1_b+0xf6)[0x751046]
./audacity(_ZN6Effect14StripAmpersandERK8wxString+0x3f)[0x82b92a7]
./audacity(_ZN13EffectManager14RegisterEffectEP6Effecti+0x66)[0x82bd72e]
./audacity(_Z11LoadEffectsv+0x30e)[0x82c458e]
./audacity(_ZN11AudacityApp6OnInitEv+0x7a3)[0x8187b13]
./audacity(_ZN12wxAppConsole10CallOnInitEv+0x18)[0x818a760]
/usr/lib/libwx_baseu-2.8.so.0(_Z7wxEntryRiPPw+0x70)[0x72b6b0]
/usr/lib/libwx_baseu-2.8.so.0(_Z7wxEntryRiPPc+0x37)[0x72b8b7]
./audacity(main+0x1b)[0x8186c8c]
/lib/libc.so.6(__libc_start_main+0xe7)[0x1410ce7]
./audacity[0x817c8b1]
======= Memory map: ========
00110000-001f1000 r-xp 00000000 08:05 1187407 /usr/lib/libwx_gtk2u_richtext-2.8.so.0.7.0
001f1000-001f2000 ---p 000e1000 08:05 1187407 /usr/lib/libwx_gtk2u_richtext-2.8.so.0.7.0
001f2000-001f8000 r--p 000e1000 08:05 1187407 /usr/lib/libwx_gtk2u_richtext-2.8.so.0.7.0
001f8000-001f9000 rw-p 000e7000 08:05 1187407 /usr/lib/libwx_gtk2u_richtext-2.8.so.0.7.0
001f9000-001fb000 rw-p 00000000 00:00 0
001fb000-00286000 r-xp 00000000 08:05 1187410 /usr/lib/libwx_gtk2u_xrc-2.8.so.0.7.0
00286000-00289000 r--p 0008b000 08:05 1187410 /usr/lib/libwx_gtk2u_xrc-2.8.so.0.7.0
00289000-0028a000 rw-p 0008e000 08:05 1187410 /usr/lib/libwx_gtk2u_xrc-2.8.so.0.7.0
0028a000-0028b000 rw-p 00000000 00:00 0
0028b000-005a5000 r-xp 00000000 08:05 1187396 /usr/lib/libwx_gtk2u_core-2.8.so.0.7.0
005a5000-005cc000 r--p 00319000 08:05 1187396 /usr/lib/libwx_gtk2u_core-2.8.so.0.7.0
005cc000-005d1000 rw-p 00340000 08:05 1187396 /usr/lib/libwx_gtk2u_core-2.8.so.0.7.0
005d1000-005d7000 rw-p 00000000 00:00 0
005d7000-005df000 r-xp 00000000 08:05 1181887 /usr/lib/libwx_baseu_xml-2.8.so.0.7.0
005df000-005e0000 r--p 00008000 08:05 1181887 /usr/lib/libwx_baseu_xml-2.8.so.0.7.0
005e0000-005e1000 rw-p 00009000 08:05 1181887 /usr/lib/libwx_baseu_xml-2.8.so.0.7.0
005e1000-0060a000 r-xp 00000000 08:05 1179916 /usr/lib/libwx_baseu_net-2.8.so.0.7.0
0060a000-0060b000 ---p 00029000 08:05 1179916 /usr/lib/libwx_baseu_net-2.8.so.0.7.0
0060b000-0060c000 r--p 00029000 08:05 1179916 /usr/lib/libwx_baseu_net-2.8.so.0.7.0
0060c000-0060d000 rw-p 0002a000 08:05 1179916 /usr/lib/libwx_baseu_net-2.8.so.0.7.0
0060d000-006a1000 r-xp 00000000 08:05 1179329 /usr/lib/libgdk-x11-2.0.so.0.2200.0
006a1000-006a3000 r--p 00094000 08:05 1179329 /usr/lib/libgdk-x11-2.0.so.0.2200.0
006a3000-006a4000 rw-p 00096000 08:05 1179329 /usr/lib/libgdk-x11-2.0.so.0.2200.0
006a4000-006ae000 r-xp 00000000 08:05 1179700 /usr/lib/libpangocairo-1.0.so.0.2800.1
006ae000-006af000 r--p 00009000 08:05 1179700 /usr/lib/libpangocairo-1.0.so.0.2800.1
006af000-006b0000 rw-p 0000a000 08:05 1179700 /usr/lib/libpangocairo-1.0.so.0.2800.1
006b1000-006b2000 r-xp 00000000 00:00 0 [vdso]
006b2000-007ea000 r-xp 00000000 08:05 1178834 /usr/lib/libwx_baseu-2.8.so.0.7.0
007ea000-007eb000 ---p 00138000 08:05 1178834 /usr/lib/libwx_baseu-2.8.so.0.7.0
007eb000-007ef000 r--p 00138000 08:05 1178834 /usr/lib/libwx_baseu-2.8.so.0.7.0
007ef000-007f1000 rw-p 0013c000 08:05 1178834 /usr/lib/libwx_baseu-2.8.so.0.7.0
007f1000-007f9000 rw-p 00000000 00:00 0
007f9000-00811000 r-xp 00000000 08:05 1179102 /usr/lib/libatk-1.0.so.0.3209.1
00811000-00812000 ---p 00018000 08:05 1179102 /usr/lib/libatk-1.0.so.0.3209.1
00812000-00813000 r--p 00018000 08:05 1179102 /usr/lib/libatk-1.0.so.0.3209.1
00813000-00814000 rw-p 00019000 08:05 1179102 /usr/lib/libatk-1.0.so.0.3209.1
00814000-0082b000 r-xp 00000000 08:05 1179331 /usr/lib/libgdk_pixbuf-2.0.so.0.2200.0
0082b000-0082c000 r--p 00017000 08:05 1179331 /usr/lib/libgdk_pixbuf-2.0.so.0.2200.0
0082c000-0082d000 rw-p 00018000 08:05 1179331 /usr/lib/libgdk_pixbuf-2.0.so.0.2200.0
0082d000-00850000 r-xp 00000000 08:05 654229 /lib/libpng12.so.0.44.0
00850000-00851000 r--p 00022000 08:05 654229 /lib/libpng12.so.0.44.0
00851000-00852000 rw-p 00023000 08:05 654229 /lib/libpng12.so.0.44.0
00852000-00891000 r-xp 00000000 08:05 1179698 /usr/lib/libpango-1.0.so.0.2800.1
00891000-00892000 ---p 0003f000 08:05 1179698 /usr/lib/libpango-1.0.so.0.2800.1
00892000-00893000 r--p 0003f000 08:05 1179698 /usr/lib/libpango-1.0.so.0.2800.1
00893000-00894000 rw-p 00040000 08:05 1179698 /usr/lib/libpango-1.0.so.0.2800.1
00894000-008c2000 r-xp 00000000 08:05 1179289 /usr/lib/libfontconfig.so.1.4.4
008c2000-008c3000 r--p 0002d000 08:05 1179289 /usr/lib/libfontconfig.so.1.4.4
008c3000-008c4000 rw-p 0002e000 08:05 1179289 /usr/lib/libfontconfig.so.1.4.4
008c4000-008c6000 r-xp 00000000 08:05 1179363 /usr/lib/libgmodule-2.0.so.0.2600.0
008c6000-008c7000 r--p 00002000 08:05 1179363 /usr/lib/libgmodule-2.0.so.0.2600.0
008c7000-008c8000 rw-p 00003000 08:05 1179363 /usr/lib/libgmodule-2.0.so.0.2600.0
008c8000-008cb000 r-xp 00000000 08:05 1179471 /usr/lib/libgthread-2.0.so.0.2600.0
008cb000-008cc000 r--p 00003000 08:05 1179471 /usr/lib/libgthread-2.0.so.0.2600.0
008cc000-008cd000 rw-p 00004000 08:05 1179471 /usr/lib/libgthread-2.0.so.0.2600.0
008cd000-008d4000 r-xp 00000000 08:05 654201 /lib/librt-2.12.1.so
008d4000-008d5000 r--p 00006000 08:05 654201 /lib/librt-2.12.1.so
008d5000-008d6000 rw-p 00007000 08:05 654201 /lib/librt-2.12.1.so
008d6000-008d8000 r-xp 00000000 08:05 654189 /lib/libdl-2.12.1.so
008d8000-008d9000 r--p 00001000 08:05 654189 /lib/libdl-2.12.1.so
008d9000-008da000 rw-p 00002000 08:05 654189 /lib/libdl-2.12.1.so
008da000-008dc000 r-xp 00000000 08:05 1179051 /usr/lib/libXinerama.so.1.0.0
008dc000-008dd000 r--p 00001000 08:05 1179051 /usr/lib/libXinerama.so.1.0.0
008dd000-008de000 rw-p 00002000 08:05 1179051 /usr/lib/libXinerama.so.1.0.0
008de000-008fa000 r-xp 00000000 08:05 654133 /lib/ld-2.12.1.so
008fa000-008fb000 r--p 0001b000 08:05 654133 /lib/ld-2.12.1.so
008fb000-008fc000 rw-p 0001c000 08:05 654133 /lib/ld-2.12.1.so
008fc000-0093c000 r-xp 00000000 08:05 1179399 /usr/lib/libgobject-2.0.so.0.2600.0
0093c000-0093d000 r--p 00040000 08:05 1179399 /usr/lib/libgobject-2.0.so.0.2600.0
0093d000-0093e000 rw-p 00041000 08:05 1179399 /usr/lib/libgobject-2.0.so.0.2600.0
0093e000-00962000 r-xp 00000000 08:05 658077 /lib/libm-2.12.1.so
00962000-00963000 r--p 00023000 08:05 658077 /lib/libm-2.12.1.so
00963000-00964000 rw-p 00024000 08:05 658077 /lib/libm-2.12.1.so
00966000-00981000 r-xp 00000000 08:05 1187406 /usr/lib/libwx_gtk2u_qa-2.8.so.0.7.0
00981000-00983000 r--p 0001a000 08:05 1187406 /usr/lib/libwx_gtk2u_qa-2.8.so.0.7.0
00983000-00984000 rw-p 0001c000 08:05 1187406 /usr/lib/libwx_gtk2u_qa-2.8.so.0.7.0
00984000-009f6000 r-xp 00000000 08:05 1192520 /usr/lib/libfreetype.so.6.6.0
009f6000-009fa000 r--p 00071000 08:05 1192520 /usr/lib/libfreetype.so.6.6.0
009fa000-009fb000 rw-p 00075000 08:05 1192520 /usr/lib/libfreetype.so.6.6.0Aborted
Newbie question: how to get audacity to run?
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Re: Newbie question: how to get audacity to run?
Does Audacity 1.3.12 from the Ubuntu repository run on your machine?
Did you try installing the Audacity package on Ubuntu before compiling from source?
Hi guys,
Thanks for replying. I did not install audacity on my laptop. I got rid of the bluetooth errors by purging package bluez-alsa from my laptop (it's not bluetooth-capable anyway). The only error left is this:
(plus the memory trace output)
Why don't you try first to install ubuntu's pre-compiled audacity package and see if that works?
From the command line: sudo apt-get install audacity
Or use your favourite graphical package manager, such as synaptic or other...
