I have a bad recording with a lot of static and background noise, and can bearly hear the persons voice. Is there a way to identify only the person's voice so you can pull only the voice out and get rid of the static and background noise?
thanks,
zrankfappa
How to pull only one person's voice from a bad recording
zrankfappa
Re: How to pull only one person's voice from a bad recording
Probably not. But if you upload a short sample (just a couple of seconds) in either WAV or Flac format, you may get some volunteers to have a go and see what can be done.
