Can't download 1.3.5 beta
Gothboy
Post by Gothboy » Sat May 10, 2008 3:19 pm
I'm having trouble downloading the 1.3.5 Audacity beta from Sourceforge. When I click on the link the Sourceforge page opens with an indication that it's downloading and then...nothing. I don't even get a popup blocker bar on top of my browser window. The 1.3.3 version downloads just fine though....so I'm thinking it's not my computer with the problem. :?:
Dual 1.4 processor G4 w. 1.25GB RAM
Tiger 10.4.11
Pro Tools LE 7.3, Audacity 1.2.6 stable, MuLab Free
Live Lite 6, Reason Adapted 3.0
hp Media center pc 873n Intel Pentium 4, 2.53.GHz.
Audacity 1.2 stable
Nec Asperra Terrent
Re: Can't download 1.3.5 beta
Post by steve » Sat May 10, 2008 3:48 pm
1.3.5 has not been out long, so demand is probably very high. I managed to download it today, so it is probably worth trying again later.
DrLex
Post by DrLex » Fri May 23, 2008 6:01 pm
I'm trying to download the Mac 1.3.5 beta but I'm getting endless redirects. It seems as if the file has been erased from all servers?
Post by steve » Fri May 23, 2008 7:31 pm
The Mac version has been changed very recently, you may need to try again in a day or two.
happywoman50
Post by happywoman50 » Fri Aug 01, 2008 1:01 pm
I managed to download 1.3.5 Audacity from Sourceforge. I think the problem is solved.
Ann, my blog is here
spoken22
Post by spoken22 » Sat Oct 18, 2008 11:43 pm
I also have a problem with my 1.3.5 beta installer it cannot download their always have a missing files say on the error message. Another problem if I delete the files it will not delete because still running but I didn't use it. How to fix in mine?.
Post by steve » Sun Oct 19, 2008 11:40 am
spoken22 wrote:Another problem if I delete the files it will not delete because still running
If you are using Windows, use the Task Manager to end the process, then delete the unwanted files.
