BAD FEEDBACK AND NO MUSIC!
jahbuzzz
Post by jahbuzzz » Fri Oct 29, 2010 11:40 am
Hi there,
i disconnected my KAM USB turntable from my iMac G5 and when I reconnected it all I get is wicked feedback and no music. Anyone know what this could be? I would really appreciate your help.
Re: BAD FEEDBACK AND NO MUSIC!
Post by steve » Fri Oct 29, 2010 12:23 pm
Do you have Soundflower installed?
jahbuzzz
Post by jahbuzzz » Fri Oct 29, 2010 1:28 pm
I dont but it worked before and I hadnt. What is soundflower?
billw58
Post by billw58 » Fri Oct 29, 2010 3:38 pm
Getting feedback when connecting a USB turntable is very strange. What version of OS X are you running on your G5?
Connect the turntable.
Go to System Preferences, Sound.
In the Output section, make sure that Line Out is selected.
In the Input section, make sure that USB Audio Codec is selected.
Start Audacity.
Go to Audacity > Preferences, then the Devices section. http://manual.audacityteam.org/index.ph ... references
Make sure the the Playback and Recording sections match the Input and Output setting you made in System Preferences.
Now try to record something from the USB turntable.
-- Bill
Post by steve » Fri Oct 29, 2010 4:28 pm
As Bill says, it is usually difficult to get feedback through a Mac. Soundflower is an add-on program that allows Mac users to open up addition sound pathways and thus makes it easier to create feedback loops. As you don't have Soundflower installed, it's not relevant. I'll duck out at this point (as I'm not a Mac user) and leave you with Bill's guidance.
jahbuzzz
Post by jahbuzzz » Sat Oct 30, 2010 5:41 pm
billw58 wrote:Getting feedback when connecting a USB turntable is very strange. What version of OS X are you running on your G5?
Start Audacity.
-- Bill
Bill! Thank you so much mate! Worked perfectly! Really appreciate it!! I would pay you if I could!
All the best!
billw58
Post by billw58 » Sat Oct 30, 2010 7:09 pm
jahbuzzz wrote: Bill! Thank you so much mate! Worked perfectly! Really appreciate it!! I would pay you if I could!
You could make a donation to the Audacity project. http://audacityteam.org/community/donate
-- Bill
