Buzzing and audio distortion after recording with mic
Re: Buzzing and audio distortion after recording with mic
Post by steve » Wed Oct 27, 2010 2:58 pm
Barni wrote:We are using a mic which plugs in with a jack
Then it's not the same problem - the issue here is specifically with USB.
Check that your recording level is not too high - the blue wiggly waveform should not touch the top or bottom of the audio track (about half the height of the track is a good recording level). If that does not fix it, try looking in the documentation (see links in my signature) or start a new topic. It is highly recommended that you use Audacity 1.3.12, so if you have an old 1.2.x version, please update.
Mac321
Post by Mac321 » Wed Oct 27, 2010 10:00 pm
Interesting.
Well the only other thing I have plugged into USB is my mouse. I tried plugging the headset into a USB port as far away form it, no luck.
Am I just out of luck? Should I just get a stereo headset?
Thanks in advance for the responses.
