as english is not my language so i can not understand all functions.i am using audacity1.2.6 windows and i want to know is it possible to record while listening on internet?
thanks
rec from internet
Re: rec from internet
<<<is it possible to record while listening on internet>>>
It is possible to record from the internet on Windows 2000 and Windows XP, but not so much Windows Vista.
On Windows XP, there is a web site to help you set the Windows audio controls.
I record from internet using Windows 2000 and a software program called Total Recorder. Total Recorder lets me set a timer so I can record Internet when I'm not home.
I have Vista, so how would I do it with Vista ?
waxcylinder
OK, so Vista is all set.
p.s.
Koz, so what are the basic steps to doing a timed recording form the
internet ?
you mentioned the total recorder, how does that sync up with audacity.... etc..
I'd like to record a stream from a radio station
p.s.
internet ?
