Won't play itunes songs.
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Ok, so I just got my itunes songs off my itouch onto my laptop, I'm using linux. But when I try to play them on audacity, it says that it recognizes the file but can't understand the file format.... So i'm stuck, I don't know what to do. I've tried putting Mp3, and wav at the end of the file but the same thing comes up, any help?
waxcylinder
Re: Won't play itunes songs.
Ok, I've downloaded the ffmpeg converter thingy with the synaptic pack manager on my LINUX. I've followed the instructions of what to do after downloading it, but now, whenever I load up the file I want on audacity, it just closes down....Any help?
It just worked once... But it's not working anymore
What Linux are you using?
Ok it seems to be working now. It's strange....I will open the file doesn't work, try a few more times and it works....
Sounds like ubuntu to meUbadood wrote:Ok it seems to be working now. It's strange....I will open the file doesn't work, try a few more times and it works....
Lol your right.bgravato wrote:Sounds like ubuntu to meUbadood wrote:Ok it seems to be working now. It's strange....I will open the file doesn't work, try a few more times and it works....
