i'm new here, but i hope you'll help me anyway.
my setup: arch linux current 64bit, and audacity from repositories with these version(s):
Code: Select all
Audacity ® 1.3.12-beta (Unicode)
Librerie principali
libsamplerate (Conversione frequenza di campionamento) Abilitato
PortAudio (Riproduzione e registrazione audio) v19
wxWidgets 2.8.10 (Unicode)
Caratteristiche
Nyquist (Supporto plug-in) Abilitato
LADSPA (Supporto plug-in) Abilitato
Vamp (Supporto plug-in) Abilitato
Audio Units (Supporto plug-in) Disabilitato
PortMixer (Supporto scheda mixer audio) Abilitato
SoundTouch (Supporto intonazione e cambio tempo) Abilitato
Informazioni sulla versione
Data di rilascio del programma: Apr 14 2010
Code: Select all
Default capture device number: 5
Default playback device number: 5
Device ID: 0
Device name: ALSA: HDA Intel: ALC1200 Analog (hw:0,0)
Input channels: 2
Output channels: 0
Low Input Latency: 0,011610
Low Output Latency: -1,000000
High Input Latency: 0,046440
High Output Latency: -1,000000
Supported Rates:
Device ID: 1
Device name: ALSA: HDA Intel: ALC1200 Digital (hw:0,1)
Input channels: 0
Output channels: 2
Low Input Latency: -1,000000
Low Output Latency: 0,011610
High Input Latency: -1,000000
High Output Latency: 0,046440
Supported Rates:
44100
48000
88200
96000
192000
Device ID: 2
Device name: ALSA: HDA Intel: ALC1200 Analog (hw:0,2)
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 3
Device name: ALSA: iec958
Input channels: 0
Output channels: 2
Supported Rates:
44100
48000
88200
96000
192000
Device ID: 4
Device name: ALSA: spdif
Input channels: 0
Output channels: 2
Supported Rates:
44100
48000
88200
96000
192000
Device ID: 5
Device name: ALSA: default
Input channels: 128
Output channels: 128
Low Input Latency: 0,042653
Low Output Latency: 0,042653
Supported Rates:
8000
9600
11025
16000
22050
32000
44100
48000
88200
Device ID: 6
Device name: ALSA: dmix
Input channels: 0
Output channels: 2
Low Output Latency: 0,042667
High Output Latency: 0,042667
Supported Rates:
48000
Device ID: 7
Device name: OSS: /dev/dsp
Input channels: 16
Output channels: 0
Low Output Latency: 0,000000
High Output Latency: 0,000000
Supported Rates:
Selected capture device: 5 - ALSA: default
Selected playback device: 5 - ALSA: default
Supported Rates:
8000
9600
11025
16000
22050
32000
44100
48000
88200
Unable to open Portmixer
i read the wiki and it says that if i have portaudio v19 i must have audacity 1.3.x and that's my case.
any idea what's going wrong? thank you
