Failed on building 1.3.12 with wxWidget 2.8.11
Building and customizing Audacity from the source code.
ve2tmq
Post by ve2tmq » Wed Oct 13, 2010 7:58 pm
Hello. I try to build Audacity 1.3.12 with wxWidget 2.8.11 and I failed. I also try with other version of wxWiget and Audacity. does anybody got the same error of me and how did you resolv it?
Thanks a lot.
This is the failure dump :
Benchmark.o: In function `BenchmarkDialog::OnSave(wxCommandEvent&)':
Benchmark.cpp:(.text+0x1172): undefined reference to `FileSelector(wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, int, wxWindow*, wxString, void (*)(void*, int), void*)'
FFmpeg.o: In function `FindFFmpegDialog::OnBrowse(wxCommandEvent&)':
FFmpeg.cpp:(.text._ZN16FindFFmpegDialog8OnBrowseER14wxCommandEvent[FindFFmpegDialog::OnBrowse(wxCommandEvent&)]+0x104): undefined reference to `FileSelector(wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, int, wxWindow*, wxString, void (*)(void*, int), void*)'
FreqWindow.o: In function `FreqWindow::OnExport(wxCommandEvent&)':
FreqWindow.cpp:(.text+0x9eeb): undefined reference to `FileSelector(wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, int, wxWindow*, wxString, void (*)(void*, int), void*)'
LabelDialog.o: In function `LabelDialog::OnImport(wxCommandEvent&)':
LabelDialog.cpp:(.text+0x3630): undefined reference to `FileSelector(wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, int, wxWindow*, wxString, void (*)(void*, int), void*)'
LabelDialog.o: In function `LabelDialog::OnExport(wxCommandEvent&)':
LabelDialog.cpp:(.text+0x3ad6): undefined reference to `FileSelector(wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, int, wxWindow*, wxString, void (*)(void*, int), void*)'
Menus.o:Menus.cpp:(.text+0xde74): more undefined references to `FileSelector(wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, int, wxWindow*, wxString, void (*)(void*, int), void*)' follow
../lib-src/FileDialog.a(FileDialog.o): In function `wxString::operator=(char const*)':
/usr/local/include/wx-2.8/wx/string.h:965: undefined reference to `wxStringBase::operator=(char const*)'
../lib-src/FileDialog.a(FileDialog.o): In function `wxStringBase':
/usr/local/include/wx-2.8/wx/string.h:368: undefined reference to `wxStringBase::InitWith(char const*, unsigned int, unsigned int)'
../lib-src/FileDialog.a(FileDialog.o): In function `FileSelector(char const*, char const*, char const*, char const*, char const*, int, wxWindow*, wxString, void (*)(void*, int), void*)':
/usr/local/src/audacity-src-1.3.12-beta/lib-src/FileDialog/FileDialog.cpp:97: undefined reference to `wxString::Find(char, bool) const'
../lib-src/FileDialog.a(FileDialog.o): In function `wxString::Contains(wxString const&) const':
/usr/local/include/wx-2.8/wx/string.h:1272: undefined reference to `wxString::Find(char const*) const'
/usr/local/src/audacity-src-1.3.12-beta/lib-src/FileDialog/FileDialog.cpp:74: undefined reference to `operator+(wxString const&, char const*)'
../lib-src/FileDialog.a(FileDialogPrivate.o): In function `FileDialog::SetDirectory(wxString const&)':
/usr/local/src/audacity-src-1.3.12-beta/lib-src/FileDialog/gtk/FileDialogPrivate.cpp:437: undefined reference to `wxDirExists(char const*)'
../lib-src/FileDialog.a(FileDialogPrivate.o): In function `wxStringBase':
../lib-src/FileDialog.a(FileDialogPrivate.o): In function `FileDialog::ShowModal()':
/usr/local/src/audacity-src-1.3.12-beta/lib-src/FileDialog/gtk/FileDialogPrivate.cpp:312: undefined reference to `wxString::Replace(char const*, char const*, bool)'
../lib-src/FileDialog.a(FileDialogPrivate.o): In function `gtk_filedialog_ok_callback':
/usr/local/src/audacity-src-1.3.12-beta/lib-src/FileDialog/gtk/FileDialogPrivate.cpp:88: undefined reference to `wxString::Printf(char const*, ...)'
../lib-src/FileDialog.a(FileDialogPrivate.o):/usr/local/include/wx-2.8/wx/string.h:368: more undefined references to `wxStringBase::InitWith(char const*, unsigned int, unsigned int)' follow
../lib-src/FileDialog.a(FileDialogPrivate.o):(.rodata._ZTV10FileDialog[vtable for FileDialog]+0x264): undefined reference to `wxWindow::ApplyToolTip(_GtkTooltips*, char const*)'
collect2: ld returned 1 exit status
make[1]: *** [../audacity] Error 1
make[1]: Leaving directory `/usr/local/src/audacity-src-1.3.12-beta/src'
make: *** [audacity] Error 2
Re: Failed on building 1.3.12 with wxWidget 2.8.11
Post by Gale Andrews » Wed Oct 13, 2010 9:40 pm
I moved this to the correct "Compiling Audacity" forum (you are not using Audacity 1.2).
What distribution of Linux are you on? Have you installed -dev packages for all your dependent libraries?
ve2tmq
Post by ve2tmq » Fri Oct 15, 2010 6:53 pm
Yes Ia have any lib I need. I have Slackware 13.1. I ever build it long time ago, I successful build audacity 1.3.7, now I failed on 1.3.12 with wxWigets 2.8.11. In the changes logs they aren't any changes suspect this error.
ve2tmq
Post by ve2tmq » Fri Oct 15, 2010 8:07 pm
Post by Gale Andrews » Fri Oct 15, 2010 9:35 pm
ve2tmq wrote:This is the solution :
http://slackbuilds.org/repository/13.1/audio/audacity/
What I am looking for exactly in that link? All I can see is the av_match_ext fix for later FFmpeg.
preethishravan
Post by preethishravan » Thu Apr 21, 2011 9:42 pm
I have been facing the same problem with audacity from svn. Can anybody tell me how to resolve it?
Edgar
Forum Crew
Post by Edgar » Thu Apr 21, 2011 11:02 pm
preethishravan,
I had go back to svn checkout -r 11014 ... to find something that would compile with Ubuntu 10.10. Read this:
http://audacity.238276.n2.nabble.com/Da ... 36157.html
on the Audacity -devel mailing list for details. In short they know it is broken but have not had time to fix it yet.
ve2tmq,
As for the OP's failure with 1.3.12, I am not sure but it looks like a problem with wxWidgets. Did you install a wxWidgets package or did you build it yourself? As for Audacity, you should grab version 11014:
Code: Select all
svn checkout -r 11014 http://audacity.googlecode.com/svn/audacity-src/trunk/ targetFolder
and try building that.
For both of you, keep an eye on:
http://code.google.com/p/audacity/updates/list
and watch for a new commit which fixes the Linux build, then use:
Code: Select all
svn checkout http://audacity.googlecode.com/svn/audacity-src/trunk/ targetFolder
to check out the SVN HEAD and build that--it is 1.3.14alpha and should be very stable for most situations.
preethishravan
Post by preethishravan » Fri Apr 22, 2011 8:48 pm
I am trying to install audacity on CentOS. I have tried using the svn version of audacity that you have suggested. However, when I do a make, I get the same old error as follows: (I am using wxWidgets 2.8.12 )
NoteTrack.o: In function `NoteTrack::WriteXML(XMLWriter&)':
NoteTrack.cpp:(.text+0x8b7): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
NoteTrack.o: In function `NoteTrack::HandleXMLTag(wchar_t const*, wchar_t const**)':
NoteTrack.cpp:(.text+0x1117): undefined reference to `wxString::mb_str(wxMBConv const&) const'
NoteTrack.o: In function `NoteTrack::ExportAllegro(wxString)':
NoteTrack.cpp:(.text+0x13c7): undefined reference to `wxString::mb_str(wxMBConv const&) const'
NoteTrack.o: In function `NoteTrack::ExportMIDI(wxString)':
NoteTrack.cpp:(.text+0x182e): undefined reference to `wxString::mb_str(wxMBConv const&) const'
NoteTrack.o: In function `NoteTrack::DrawLabelControls(wxDC&, wxRect&)':
NoteTrack.cpp:(.text+0x24ab): undefined reference to `wxString::Printf(wchar_t const*, ...)'
import/ImportMIDI.o: In function `ImportMIDI(wxString, NoteTrack*)':
ImportMIDI.cpp:(.text+0x77): undefined reference to `operator+(wchar_t const*, wxString const&)'
ImportMIDI.cpp:(.text+0x96): undefined reference to `operator+(wxString const&, wchar_t const*)'
ImportMIDI.cpp:(.text+0x1ad): undefined reference to `wxString::CmpNoCase(wchar_t const*) const'
ImportMIDI.cpp:(.text+0x1e8): undefined reference to `wxString::CmpNoCase(wchar_t const*) const'
ImportMIDI.cpp:(.text+0x2e5): undefined reference to `wxString::CmpNoCase(wchar_t const*) const'
ImportMIDI.cpp:(.text+0x381): undefined reference to `operator+(wchar_t const*, wxString const&)'
ImportMIDI.cpp:(.text+0x3a0): undefined reference to `operator+(wxString const&, wchar_t const*)'
ImportMIDI.cpp:(.text+0x490): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
ImportMIDI.cpp:(.text+0x4e4): undefined reference to `operator+(wchar_t const*, wxString const&)'
ImportMIDI.cpp:(.text+0x501): undefined reference to `operator+(wxString const&, wchar_t const*)'
ImportMIDI.cpp:(.text+0x5e6): undefined reference to `wxString::mb_str(wxMBConv const&) const'
ImportMIDI.cpp:(.text+0x6e5): undefined reference to `operator+(wchar_t const*, wxString const&)'
ImportMIDI.cpp:(.text+0x702): undefined reference to `operator+(wxString const&, wchar_t const*)'
ImportMIDI.cpp:(.text+0x819): undefined reference to `wxString::AfterLast(wchar_t) const'
ImportMIDI.cpp:(.text+0x839): undefined reference to `wxString::BeforeLast(wchar_t) const'
effects/ladspa/LoadLadspa.o: In function `LoadLadspaEffect(wxSortedArrayString&, wxString, DL_Array&)':
LoadLadspa.cpp:(.text+0x171): undefined reference to `wxString::CmpNoCase(wchar_t const*) const'
LoadLadspa.cpp:(.text+0x301): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
LoadLadspa.cpp:(.text+0x32e): undefined reference to `wxString::Format(wchar_t const*, ...)'
LoadLadspa.cpp:(.text+0x366): undefined reference to `wxArrayString::Index(wchar_t const*, bool, bool) const'
effects/ladspa/LoadLadspa.o: In function `LoadLadspaPlugins()':
LoadLadspa.cpp:(.text+0x603): undefined reference to `wxGetenv(wchar_t const*)'
LoadLadspa.cpp:(.text+0x79b): undefined reference to `operator+(wxString const&, wchar_t)'
LoadLadspa.cpp:(.text+0x7bd): undefined reference to `operator+(wxString const&, wchar_t const*)'
LoadLadspa.cpp:(.text+0x817): undefined reference to `operator+(wxString const&, wchar_t const*)'
LoadLadspa.cpp:(.text+0x86e): undefined reference to `operator+(wxString const&, wchar_t const*)'
effects/ladspa/LadspaEffect.o: In function `LadspaEffect::GetEffectAction()':
LadspaEffect.cpp:(.text+0x324): undefined reference to `wxString::Format(wchar_t const*, ...)'
effects/ladspa/LadspaEffect.o: In function `LadspaEffectDialog::OnSlider(wxCommandEvent&)':
LadspaEffect.cpp:(.text+0xd64): undefined reference to `wxString::Printf(wchar_t const*, ...)'
effects/ladspa/LadspaEffect.o: In function `LadspaEffect::GetEffectName()':
LadspaEffect.cpp:(.text+0x120a): undefined reference to `operator+(wxString const&, wchar_t const*)'
effects/ladspa/LadspaEffect.o: In function `LadspaEffectDialog::LadspaEffectDialog(LadspaEffect*, wxWindow*, _LADSPA_Descriptor const*, float*, int, double)':
LadspaEffect.cpp:(.text+0x128d): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
LadspaEffect.cpp:(.text+0x15cd): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
LadspaEffect.cpp:(.text+0x16ed): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
LadspaEffect.cpp:(.text+0x1980): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
LadspaEffect.cpp:(.text+0x1aa0): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
effects/ladspa/LadspaEffect.o:LadspaEffect.cpp:(.text+0x209e): more undefined references to `wxString::wxString(char const*, wxMBConv const&, unsigned int)' follow
LadspaEffect.cpp:(.text+0x20be): undefined reference to `operator+(wxString const&, wchar_t const*)'
LadspaEffect.cpp:(.text+0x25f3): undefined reference to `wxString::Printf(wchar_t const*, ...)'
LadspaEffect.cpp:(.text+0x2915): undefined reference to `wxString::Printf(wchar_t const*, ...)'
LadspaEffect.cpp:(.text+0x2cf6): undefined reference to `wxString::Printf(wchar_t const*, ...)'
LadspaEffect.cpp:(.text+0x3683): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
LadspaEffect.cpp:(.text+0x39c3): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
LadspaEffect.cpp:(.text+0x3ae3): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
LadspaEffect.cpp:(.text+0x3d76): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
LadspaEffect.cpp:(.text+0x3e96): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
effects/ladspa/LadspaEffect.o:LadspaEffect.cpp:(.text+0x4494): more undefined references to `wxString::wxString(char const*, wxMBConv const&, unsigned int)' follow
LadspaEffect.cpp:(.text+0x44b4): undefined reference to `operator+(wxString const&, wchar_t const*)'
LadspaEffect.cpp:(.text+0x49e9): undefined reference to `wxString::Printf(wchar_t const*, ...)'
LadspaEffect.cpp:(.text+0x4d0b): undefined reference to `wxString::Printf(wchar_t const*, ...)'
LadspaEffect.cpp:(.text+0x50ec): undefined reference to `wxString::Printf(wchar_t const*, ...)'
effects/ladspa/LadspaEffect.o: In function `LadspaEffect::LadspaEffect(_LADSPA_Descriptor const*, std::set<wxString, std::less<wxString>, std::allocator<wxString> > const&)':
LadspaEffect.cpp:(.text+0x6950): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
LadspaEffect.cpp:(.text+0x6dec): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
effects/ladspa/LadspaEffect.o:(.rodata._ZTV18LadspaEffectDialog[vtable for LadspaEffectDialog]+0x264): undefined reference to `wxWindow::ApplyToolTip(_GtkTooltips*, wchar_t const*)'
effects/ladspa/LadspaEffect.o:(.rodata._ZTV8TextCtrl[vtable for TextCtrl]+0x264): undefined reference to `wxWindow::ApplyToolTip(_GtkTooltips*, wchar_t const*)'
effects/ladspa/LadspaEffect.o:(.rodata._ZTV6Slider[vtable for Slider]+0x264): undefined reference to `wxWindow::ApplyToolTip(_GtkTooltips*, wchar_t const*)'
../lib-src/FileDialog.a(FileDialog.o): In function `wxString::operator=(wchar_t const*)':
/usr/local/include/wx-2.8/wx/string.h:965: undefined reference to `wxStringBase::operator=(wchar_t const*)'
/usr/local/include/wx-2.8/wx/string.h:368: undefined reference to `wxStringBase::InitWith(wchar_t const*, unsigned int, unsigned int)'
../lib-src/FileDialog.a(FileDialog.o): In function `FileSelector(wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, wchar_t const*, int, wxWindow*, wxString, void (*)(void*, int), void*)':
/home/ppoddat/targetFolder/lib-src/FileDialog/FileDialog.cpp:97: undefined reference to `wxString::Find(wchar_t, bool) const'
/usr/local/include/wx-2.8/wx/string.h:1272: undefined reference to `wxString::Find(wchar_t const*) const'
/home/ppoddat/targetFolder/lib-src/FileDialog/FileDialog.cpp:74: undefined reference to `operator+(wxString const&, wchar_t const*)'
/home/ppoddat/targetFolder/lib-src/FileDialog/gtk/FileDialogPrivate.cpp:437: undefined reference to `wxDirExists(wchar_t const*)'
/home/ppoddat/targetFolder/lib-src/FileDialog/gtk/FileDialogPrivate.cpp:312: undefined reference to `wxString::Replace(wchar_t const*, wchar_t const*, bool)'
/home/ppoddat/targetFolder/lib-src/FileDialog/gtk/FileDialogPrivate.cpp:88: undefined reference to `wxString::Printf(wchar_t const*, ...)'
../lib-src/FileDialog.a(FileDialogPrivate.o):/usr/local/include/wx-2.8/wx/string.h:368: more undefined references to `wxStringBase::InitWith(wchar_t const*, unsigned int, unsigned int)' follow
../lib-src/FileDialog.a(FileDialogPrivate.o):(.rodata._ZTV10FileDialog[vtable for FileDialog]+0x264): undefined reference to `wxWindow::ApplyToolTip(_GtkTooltips*, wchar_t const*)'
libaudacity.a(BlockFile.o): In function `AliasBlockFile::GetSpaceUsage()':
BlockFile.cpp:(.text+0x327): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
libaudacity.a(BlockFile.o): In function `AliasBlockFile::ReadSummary(void*)':
BlockFile.cpp:(.text+0x43a): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
libaudacity.a(BlockFile.o): In function `AliasBlockFile::WriteSummary()':
BlockFile.cpp:(.text+0x19c7): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
BlockFile.cpp:(.text+0x1a43): undefined reference to `wxLogError(wchar_t const*, ...)'
libaudacity.a(BlockFile.o): In function `AliasBlockFile::AliasBlockFile(wxFileName, wxFileName, long long, long long, int)':
BlockFile.cpp:(.text+0x21e6): undefined reference to `operator+(wxString const&, wchar_t const*)'
BlockFile.cpp:(.text+0x235a): undefined reference to `operator+(wxString const&, wchar_t const*)'
libaudacity.a(DirManager.o): In function `RecursivelyEnumerate(wxString, wxArrayString&, wxString, bool, bool, int, int, ProgressDialog*)':
DirManager.cpp:(.text+0x612): undefined reference to `operator+(wxString const&, wchar_t)'
DirManager.cpp:(.text+0x75f): undefined reference to `operator+(wxString const&, wchar_t)'
libaudacity.a(DirManager.o): In function `DirManager::FindOrphanBlockFiles(wxArrayString const&, wxArrayString&)':
DirManager.cpp:(.text+0xdb1): undefined reference to `wxLogWarning(wchar_t const*, ...)'
libaudacity.a(DirManager.o): In function `DirManager::FindMissingAliasedFiles(BlockHash&, BlockHash&)':
DirManager.cpp:(.text+0x12b5): undefined reference to `wxLogWarning(wchar_t const*, ...)'
libaudacity.a(DirManager.o): In function `RecursivelyCountSubdirs(wxString)':
DirManager.cpp:(.text+0x1465): undefined reference to `operator+(wxString const&, wchar_t)'
libaudacity.a(DirManager.o): In function `RecursivelyRemoveEmptyDirs(wxString, int, ProgressDialog*)':
DirManager.cpp:(.text+0x16ab): undefined reference to `operator+(wxString const&, wchar_t)'
libaudacity.a(DirManager.o): In function `DirManager::EnsureSafeFilename(wxFileName)':
DirManager.cpp:(.text+0x2538): undefined reference to `wxArrayString::Index(wchar_t const*, bool, bool) const'
DirManager.cpp:(.text+0x2612): undefined reference to `wxString::Format(wchar_t const*, ...)'
DirManager.cpp:(.text+0x2700): undefined reference to `wxFile::wxFile(wchar_t const*, wxFile::OpenMode)'
DirManager.cpp:(.text+0x27aa): undefined reference to `wxLogSysError(wchar_t const*, ...)'
DirManager.cpp:(.text+0x28c9): undefined reference to `wxLogSysError(wchar_t const*, ...)'
DirManager.cpp:(.text+0x2968): undefined reference to `wxPrintf(wchar_t const*, ...)'
DirManager.cpp:(.text+0x3086): undefined reference to `wxLogSysError(wchar_t const*, ...)'
DirManager.cpp:(.text+0x3310): undefined reference to `wxPrintf(wchar_t const*, ...)'
DirManager.cpp:(.text+0x3558): undefined reference to `wxArrayString::Remove(wchar_t const*)'
libaudacity.a(DirManager.o): In function `DirManager::HandleXMLTag(wchar_t const*, wchar_t const**)':
DirManager.cpp:(.text+0x3a0d): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
DirManager.cpp:(.text+0x3a4f): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
DirManager.cpp:(.text+0x3a85): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
DirManager.cpp:(.text+0x3abb): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
DirManager.cpp:(.text+0x3af6): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
libaudacity.a(DirManager.o):DirManager.cpp:(.text+0x3b31): more undefined references to `wxStricmp(wchar_t const*, wchar_t const*)' follow
DirManager.cpp:(.text+0x3bac): undefined reference to `wxAtoi(wchar_t const*)'
libaudacity.a(DirManager.o): In function `DirManager::MakeBlockFilePath(wxString)':
DirManager.cpp:(.text+0x4618): undefined reference to `wxString::Find(wchar_t, bool) const'
DirManager.cpp:(.text+0x47e6): undefined reference to `wxLogSysError(wchar_t const*, ...)'
libaudacity.a(DirManager.o): In function `DirManager::FindMissingAUs(BlockHash&)':
DirManager.cpp:(.text+0x4a04): undefined reference to `wxLogWarning(wchar_t const*, ...)'
libaudacity.a(DirManager.o): In function `DirManager::FindMissingAUFs(BlockHash&)':
DirManager.cpp:(.text+0x4cb1): undefined reference to `wxLogWarning(wchar_t const*, ...)'
libaudacity.a(DirManager.o): In function `DirManager::ProjectFSCK(bool, bool)':
DirManager.cpp:(.text+0x503d): undefined reference to `wxString::Printf(wchar_t const*, ...)'
DirManager.cpp:(.text+0x53b8): undefined reference to `wxLogWarning(wchar_t const*, ...)'
DirManager.cpp:(.text+0x54c9): undefined reference to `wxString::Printf(wchar_t const*, ...)'
DirManager.cpp:(.text+0x5769): undefined reference to `wxLogWarning(wchar_t const*, ...)'
DirManager.cpp:(.text+0x587a): undefined reference to `wxString::Printf(wchar_t const*, ...)'
DirManager.cpp:(.text+0x5b1a): undefined reference to `wxLogWarning(wchar_t const*, ...)'
DirManager.cpp:(.text+0x5ba9): undefined reference to `wxLogWarning(wchar_t const*, ...)'
DirManager.cpp:(.text+0x5c1d): undefined reference to `wxString::Printf(wchar_t const*, ...)'
DirManager.cpp:(.text+0x6071): undefined reference to `wxLogWarning(wchar_t const*, ...)'
libaudacity.a(DirManager.o): In function `DirManager::AssignFile(wxFileName&, wxString, bool)':
DirManager.cpp:(.text+0x63f8): undefined reference to `wxString::Printf(wchar_t const*, ...)'
DirManager.cpp:(.text+0x646f): undefined reference to `wxLogWarning(wchar_t const*, ...)'
libaudacity.a(DirManager.o): In function `DirManager::MakeBlockFileName()':
DirManager.cpp:(.text+0x71b0): undefined reference to `wxString::Printf(wchar_t const*, ...)'
libaudacity.a(DirManager.o): In function `DirManager::SetProject(wxString&, wxString&, bool)':
DirManager.cpp:(.text+0x8319): undefined reference to `operator+(wxString const&, wchar_t)'
DirManager.cpp:(.text+0x83f0): undefined reference to `wxDirExists(wchar_t const*)'
DirManager.cpp:(.text+0x8441): undefined reference to `wxString::mb_str(wxMBConv const&) const'
DirManager.cpp:(.text+0x8482): undefined reference to `wxDirExists(wchar_t const*)'
libaudacity.a(DirManager.o): In function `DirManager::DirManager()':
DirManager.cpp:(.text+0x8d51): undefined reference to `wxString::Format(wchar_t const*, ...)'
DirManager.cpp:(.text+0x8d6f): undefined reference to `operator+(wxString const&, wchar_t)'
DirManager.cpp:(.text+0x8ddf): undefined reference to `wxDirExists(wchar_t const*)'
DirManager.cpp:(.text+0x92cd): undefined reference to `wxString::Format(wchar_t const*, ...)'
DirManager.cpp:(.text+0x92eb): undefined reference to `operator+(wxString const&, wchar_t)'
DirManager.cpp:(.text+0x935b): undefined reference to `wxDirExists(wchar_t const*)'
libaudacity.a(FileFormats.o): In function `sf_encoding_name(int)':
FileFormats.cpp:(.text+0x254): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
libaudacity.a(FileFormats.o): In function `sf_header_extension(int)':
FileFormats.cpp:(.text+0x2d4): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
libaudacity.a(FileFormats.o): In function `sf_header_name(int)':
FileFormats.cpp:(.text+0x354): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
libaudacity.a(FileFormats.o): In function `sf_encoding_index_name(int)':
FileFormats.cpp:(.text+0x3cf): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
libaudacity.a(FileFormats.o): In function `sf_header_index_name(int)':
FileFormats.cpp:(.text+0x449): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
libaudacity.a(FileFormats.o):FileFormats.cpp:(.text+0x4fa): more undefined references to `wxString::wxString(char const*, wxMBConv const&, unsigned int)' follow
libaudacity.a(Prefs.o): In function `CopyEntriesRecursive(wxString, wxConfigBase*, wxConfigBase*)':
Prefs.cpp:(.text+0x46b): undefined reference to `operator+(wxString const&, wchar_t const*)'
libaudacity.a(Sequence.o): In function `Sequence::DebugPrintf(wxString*)':
Sequence.cpp:(.text+0xe52): undefined reference to `wxString::Format(wchar_t const*, ...)'
Sequence.cpp:(.text+0xfca): undefined reference to `wxString::Format(wchar_t const*, ...)'
libaudacity.a(Sequence.o): In function `Sequence::ConsistencyCheck(wchar_t const*)':
Sequence.cpp:(.text+0x10ec): undefined reference to `wxLogError(wchar_t const*, ...)'
Sequence.cpp:(.text+0x1124): undefined reference to `wxLogError(wchar_t const*, ...)'
Sequence.cpp:(.text+0x1130): undefined reference to `wxLogError(wchar_t const*, ...)'
libaudacity.a(Sequence.o): In function `Sequence::Read(char*, sampleFormat, SeqBlock*, long long, long long) const':
Sequence.cpp:(.text+0x1a66): undefined reference to `wxLogError(wchar_t const*, ...)'
libaudacity.a(Sequence.o): In function `Sequence::HandleXMLEndTag(wchar_t const*)':
Sequence.cpp:(.text+0x4bd5): undefined reference to `wxLogWarning(wchar_t const*, ...)'
Sequence.cpp:(.text+0x4ca8): undefined reference to `wxLogWarning(wchar_t const*, ...)'
Sequence.cpp:(.text+0x4d3c): undefined reference to `wxLogWarning(wchar_t const*, ...)'
libaudacity.a(Internat.o): In function `Internat::SanitiseFilename(wxString const&, wxString const&)':
Internat.cpp:(.text+0x2e1): undefined reference to `wxString::Replace(wchar_t const*, wchar_t const*, bool)'
libaudacity.a(Internat.o): In function `Internat::ToDisplayString(double, int)':
Internat.cpp:(.text+0x38a): undefined reference to `wxString::Printf(wchar_t const*, ...)'
Internat.cpp:(.text+0x3b4): undefined reference to `wxString::Replace(wchar_t const*, wchar_t const*, bool)'
Internat.cpp:(.text+0x3ce): undefined reference to `wxString::Find(wchar_t const*) const'
Internat.cpp:(.text+0x4ce): undefined reference to `wxString::Printf(wchar_t const*, ...)'
Internat.cpp:(.text+0x4ef): undefined reference to `wxString::Printf(wchar_t const*, ...)'
Internat.cpp:(.text+0x519): undefined reference to `wxString::Replace(wchar_t const*, wchar_t const*, bool)'
libaudacity.a(Internat.o): In function `Internat::FormatSize(double)':
Internat.cpp:(.text+0x643): undefined reference to `operator+(wxString const&, wchar_t const*)'
Internat.cpp:(.text+0x65f): undefined reference to `operator+(wxString const&, wchar_t const*)'
Internat.cpp:(.text+0x74a): undefined reference to `operator+(wxString const&, wchar_t const*)'
Internat.cpp:(.text+0x766): undefined reference to `operator+(wxString const&, wchar_t const*)'
Internat.cpp:(.text+0x851): undefined reference to `operator+(wxString const&, wchar_t const*)'
libaudacity.a(Internat.o):Internat.cpp:(.text+0x86d): more undefined references to `operator+(wxString const&, wchar_t const*)' follow
libaudacity.a(Internat.o): In function `Internat::ToString(double, int)':
Internat.cpp:(.text+0xadd): undefined reference to `wxString::Replace(wchar_t const*, wchar_t const*, bool)'
libaudacity.a(Internat.o): In function `Internat::CompatibleToDouble(wxString const&, double*)':
Internat.cpp:(.text+0xb89): undefined reference to `wxString::Replace(wchar_t const*, wchar_t const*, bool)'
Internat.cpp:(.text+0xbf2): undefined reference to `wxString::Replace(wchar_t const*, wchar_t const*, bool)'
libaudacity.a(Internat.o): In function `Internat::Init()':
Internat.cpp:(.text+0xcc6): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
libaudacity.a(LegacyBlockFile.o): In function `LegacyBlockFile::GetSpaceUsage()':
LegacyBlockFile.cpp:(.text+0x4b): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
libaudacity.a(LegacyBlockFile.o): In function `LegacyBlockFile::ReadData(char*, sampleFormat, long long, long long)':
LegacyBlockFile.cpp:(.text+0x371): undefined reference to `wxFile::Open(wchar_t const*, wxFile::OpenMode, int)'
libaudacity.a(LegacyBlockFile.o): In function `LegacyBlockFile::ReadSummary(void*)':
LegacyBlockFile.cpp:(.text+0x6ea): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
libaudacity.a(LegacyBlockFile.o): In function `ComputeLegacySummaryInfo(wxFileName, int, sampleFormat, SummaryInfo*, bool, bool, float*, float*, float*)':
LegacyBlockFile.cpp:(.text+0xab5): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
LegacyBlockFile.cpp:(.text+0xb4e): undefined reference to `wxLogWarning(wchar_t const*, ...)'
libaudacity.a(LegacyBlockFile.o): In function `LegacyBlockFile::BuildFromXML(wxString, wchar_t const**, long long, sampleFormat)':
LegacyBlockFile.cpp:(.text+0x111f): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
libaudacity.a(LegacyAliasBlockFile.o): In function `LegacyAliasBlockFile::BuildFromXML(wxString, wchar_t const**)':
LegacyAliasBlockFile.cpp:(.text+0x5ed): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
LegacyAliasBlockFile.cpp:(.text+0x7a0): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
LegacyAliasBlockFile.cpp:(.text+0xa3f): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
LegacyAliasBlockFile.cpp:(.text+0xa89): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
libaudacity.a(LegacyAliasBlockFile.o):LegacyAliasBlockFile.cpp:(.text+0xad3): more undefined references to `wxStricmp(wchar_t const*, wchar_t const*)' follow
libaudacity.a(SimpleBlockFile.o): In function `SimpleBlockFile::Recover()':
SimpleBlockFile.cpp:(.text+0x1f7): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
libaudacity.a(SimpleBlockFile.o): In function `SimpleBlockFile::WriteSimpleBlockFile(char*, long long, sampleFormat, void*)':
SimpleBlockFile.cpp:(.text+0x3a3): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
libaudacity.a(SimpleBlockFile.o): In function `SimpleBlockFile::GetSpaceUsage()':
SimpleBlockFile.cpp:(.text+0x689): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
libaudacity.a(SimpleBlockFile.o): In function `SimpleBlockFile::ReadData(char*, sampleFormat, long long, long long)':
SimpleBlockFile.cpp:(.text+0xa53): undefined reference to `wxFile::Open(wchar_t const*, wxFile::OpenMode, int)'
libaudacity.a(SimpleBlockFile.o): In function `SimpleBlockFile::ReadSummary(void*)':
SimpleBlockFile.cpp:(.text+0xda8): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
libaudacity.a(SimpleBlockFile.o): In function `SimpleBlockFile::FillCache()':
SimpleBlockFile.cpp:(.text+0xfa2): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
libaudacity.a(SimpleBlockFile.o): In function `SimpleBlockFile::BuildFromXML(DirManager&, wchar_t const**)':
SimpleBlockFile.cpp:(.text+0x1502): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
SimpleBlockFile.cpp:(.text+0x187d): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
SimpleBlockFile.cpp:(.text+0x18a1): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
SimpleBlockFile.cpp:(.text+0x18c5): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
libaudacity.a(SimpleBlockFile.o): In function `SimpleBlockFile::SimpleBlockFile(wxFileName, char*, long long, sampleFormat, bool, bool)':
SimpleBlockFile.cpp:(.text+0x1b52): undefined reference to `operator+(wxString const&, wchar_t const*)'
SimpleBlockFile.cpp:(.text+0x1df2): undefined reference to `operator+(wxString const&, wchar_t const*)'
libaudacity.a(PCMAliasBlockFile.o): In function `PCMAliasBlockFile::ReadData(char*, sampleFormat, long long, long long)':
PCMAliasBlockFile.cpp:(.text+0x3eb): undefined reference to `wxFile::Exists(wchar_t const*)'
PCMAliasBlockFile.cpp:(.text+0x464): undefined reference to `wxFile::Open(wchar_t const*, wxFile::OpenMode, int)'
libaudacity.a(PCMAliasBlockFile.o): In function `PCMAliasBlockFile::BuildFromXML(DirManager&, wchar_t const**)':
PCMAliasBlockFile.cpp:(.text+0x9bd): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
PCMAliasBlockFile.cpp:(.text+0xbb7): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
PCMAliasBlockFile.cpp:(.text+0xeaa): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
PCMAliasBlockFile.cpp:(.text+0xef4): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
PCMAliasBlockFile.cpp:(.text+0xf3e): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
libaudacity.a(PCMAliasBlockFile.o):PCMAliasBlockFile.cpp:(.text+0xf90): more undefined references to `wxStricmp(wchar_t const*, wchar_t const*)' follow
libaudacity.a(ODPCMAliasBlockFile.o): In function `ODPCMAliasBlockFile::ReadSummary(void*)':
ODPCMAliasBlockFile.cpp:(.text+0x1ba): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
libaudacity.a(ODPCMAliasBlockFile.o): In function `ODPCMAliasBlockFile::ReadData(char*, sampleFormat, long long, long long)':
ODPCMAliasBlockFile.cpp:(.text+0x46a): undefined reference to `wxFile::Exists(wchar_t const*)'
ODPCMAliasBlockFile.cpp:(.text+0x49b): undefined reference to `wxFile::Open(wchar_t const*, wxFile::OpenMode, int)'
libaudacity.a(ODPCMAliasBlockFile.o): In function `ODPCMAliasBlockFile::WriteSummary()':
ODPCMAliasBlockFile.cpp:(.text+0x11a9): undefined reference to `wxString::mb_str(wxMBConv const&) const'
ODPCMAliasBlockFile.cpp:(.text+0x1205): undefined reference to `wxString::mb_str(wxMBConv const&) const'
libaudacity.a(ODPCMAliasBlockFile.o): In function `ODPCMAliasBlockFile::GetSpaceUsage()':
ODPCMAliasBlockFile.cpp:(.text+0x1a6a): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
libaudacity.a(ODPCMAliasBlockFile.o): In function `ODPCMAliasBlockFile::BuildFromXML(DirManager&, wchar_t const**)':
ODPCMAliasBlockFile.cpp:(.text+0x2c34): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
ODPCMAliasBlockFile.cpp:(.text+0x2e2e): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
ODPCMAliasBlockFile.cpp:(.text+0x3115): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
ODPCMAliasBlockFile.cpp:(.text+0x3167): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
ODPCMAliasBlockFile.cpp:(.text+0x31b6): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
libaudacity.a(ODDecodeBlockFile.o): In function `ODDecodeBlockFile::GetSpaceUsage()':
ODDecodeBlockFile.cpp:(.text+0x136d): undefined reference to `wxFFile::wxFFile(wchar_t const*, wchar_t const*)'
libaudacity.a(ODDecodeBlockFile.o): In function `ODDecodeBlockFile::BuildFromXML(DirManager&, wchar_t const**)':
ODDecodeBlockFile.cpp:(.text+0x20c7): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
ODDecodeBlockFile.cpp:(.text+0x22c1): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
ODDecodeBlockFile.cpp:(.text+0x25a8): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
ODDecodeBlockFile.cpp:(.text+0x25fa): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
ODDecodeBlockFile.cpp:(.text+0x2649): undefined reference to `wxStricmp(wchar_t const*, wchar_t const*)'
libaudacity.a(ODDecodeBlockFile.o):ODDecodeBlockFile.cpp:(.text+0x2698): more undefined references to `wxStricmp(wchar_t const*, wchar_t const*)' follow
libaudacity.a(XMLTagHandler.o): In function `XMLTagHandler::ReadXMLChild(char const*)':
XMLTagHandler.cpp:(.text+0xac): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
libaudacity.a(XMLTagHandler.o): In function `XMLTagHandler::ReadXMLContent(char const*, int)':
XMLTagHandler.cpp:(.text+0x131): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
libaudacity.a(XMLTagHandler.o): In function `XMLTagHandler::ReadXMLEndTag(char const*)':
XMLTagHandler.cpp:(.text+0x1a8): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
libaudacity.a(XMLTagHandler.o): In function `XMLTagHandler::ReadXMLTag(char const*, char const**)':
XMLTagHandler.cpp:(.text+0x237): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
XMLTagHandler.cpp:(.text+0x32e): undefined reference to `wxString::wxString(char const*, wxMBConv const&, unsigned int)'
libaudacity.a(XMLTagHandler.o): In function `XMLValueChecker::IsGoodString(wxString)':
XMLTagHandler.cpp:(.text+0x3f1): undefined reference to `wxString::Find(wchar_t, bool) const'
libaudacity.a(XMLTagHandler.o): In function `XMLValueChecker::IsGoodFileString(wxString)':
XMLTagHandler.cpp:(.text+0x79a): undefined reference to `wxString::Find(wchar_t, bool) const'
make[1]: Leaving directory `/home/ppoddat/targetFolder/src'
Thanks!
Edgar
Forum Crew
Post by Edgar » Fri Apr 22, 2011 11:33 pm
preethishravan wrote:I am trying to install audacity on CentOS. I have tried using the svn version of audacity that you have suggested. However, when I do a make, I get the same old error as follows: (I am using wxWidgets 2.8.12 )
wxWidgets 2.8.12 is not supported by Audacity. It will work on Windows (I have not tested it with Linux) as far a compiling and running but there may very well be some GUI inconsistencies.
Get the wxWidgets 2.8.11 wxGTK source code and build it from scratch from here:
http://biolpc22.york.ac.uk/pub/2.8.11/
Good instructions on how to proceed may be found here:
http://wiki.wxwidgets.org/Compiling_and_getting_started
Doing the configure, make & make install steps will insure that the wxWidgets header files can be seen during the Audacity build.
preethishravan
Post by preethishravan » Tue Apr 26, 2011 6:45 pm
I got the wxWidgets 2.8.11 wxGTK source code and build it from scratch. I used svn checkout -r 11014 http://audacity.googlecode.com/svn/audacity-src/trunk/ targetFolder and now make and make install work fine. Thank you very much.
However, my goal is to perform scripting in audacity and the "make" in lib-src/mod-script-pipe gives me the following errors:
/usr/local/include/wx/chkconf.h:47:9: error: #error "wxUSE_DYNLIB_CLASS must be defined."
/usr/local/include/wx/chkconf.h:55:9: error: #error "wxUSE_FILESYSTEM must be defined."
/usr/local/include/wx/chkconf.h:68:9: error: #error "wxUSE_DYNAMIC_LOADER must be defined."
/usr/local/include/wx/chkconf.h:76:9: error: #error "wxUSE_LOG must be defined."
/usr/local/include/wx/chkconf.h:84:9: error: #error "wxUSE_LONGLONG must be defined."
/usr/local/include/wx/chkconf.h:92:9: error: #error "wxUSE_MIMETYPE must be defined."
/usr/local/include/wx/chkconf.h:100:9: error: #error "wxUSE_PROLOGIO must be defined."
/usr/local/include/wx/chkconf.h:108:9: error: #error "wxUSE_PROTOCOL must be defined."
/usr/local/include/wx/chkconf.h:150:9: error: #error "wxUSE_REGEX must be defined."
/usr/local/include/wx/chkconf.h:158:9: error: #error "wxUSE_SOCKETS must be defined."
/usr/local/include/wx/chkconf.h:166:9: error: #error "wxUSE_STREAMS must be defined."
/usr/local/include/wx/chkconf.h:174:9: error: #error "wxUSE_STOPWATCH must be defined."
/usr/local/include/wx/chkconf.h:182:9: error: #error "wxUSE_TEXTBUFFER must be defined."
/usr/local/include/wx/chkconf.h:190:9: error: #error "wxUSE_TEXTFILE must be defined."
/usr/local/include/wx/chkconf.h:198:9: error: #error "wxUSE_UNICODE must be defined."
/usr/local/include/wx/chkconf.h:206:9: error: #error "wxUSE_URL must be defined."
/usr/local/include/wx/chkconf.h:224:9: error: #error "wxUSE_ACCEL must be defined."
/usr/local/include/wx/chkconf.h:232:9: error: #error "wxUSE_BMPBUTTON must be defined."
/usr/local/include/wx/chkconf.h:240:9: error: #error "wxUSE_BUTTON must be defined."
/usr/local/include/wx/chkconf.h:248:9: error: #error "wxUSE_CALENDARCTRL must be defined."
/usr/local/include/wx/chkconf.h:256:9: error: #error "wxUSE_CARET must be defined."
/usr/local/include/wx/chkconf.h:264:9: error: #error "wxUSE_CHECKBOX must be defined."
/usr/local/include/wx/chkconf.h:272:9: error: #error "wxUSE_CHECKLISTBOX must be defined."
/usr/local/include/wx/chkconf.h:280:9: error: #error "wxUSE_CHOICE must be defined."
/usr/local/include/wx/chkconf.h:288:9: error: #error "wxUSE_CHOICEDLG must be defined."
/usr/local/include/wx/chkconf.h:296:9: error: #error "wxUSE_CLIPBOARD must be defined."
/usr/local/include/wx/chkconf.h:304:9: error: #error "wxUSE_COLOURDLG must be defined."
/usr/local/include/wx/chkconf.h:312:9: error: #error "wxUSE_COMBOBOX must be defined."
/usr/local/include/wx/chkconf.h:320:9: error: #error "wxUSE_DATAOBJ must be defined."
/usr/local/include/wx/chkconf.h:328:9: error: #error "wxUSE_DOC_VIEW_ARCHITECTURE must be defined."
/usr/local/include/wx/chkconf.h:336:9: error: #error "wxUSE_FILEDLG must be defined."
/usr/local/include/wx/chkconf.h:344:9: error: #error "wxUSE_FONTDLG must be defined."
/usr/local/include/wx/chkconf.h:352:9: error: #error "wxUSE_FONTMAP must be defined."
/usr/local/include/wx/chkconf.h:360:9: error: #error "wxUSE_GAUGE must be defined."
/usr/local/include/wx/chkconf.h:368:9: error: #error "wxUSE_GRID must be defined."
/usr/local/include/wx/chkconf.h:376:9: error: #error "wxUSE_HELP must be defined."
/usr/local/include/wx/chkconf.h:384:9: error: #error "wxUSE_HTML must be defined."
/usr/local/include/wx/chkconf.h:392:9: error: #error "wxUSE_ICO_CUR must be defined."
/usr/local/include/wx/chkconf.h:400:9: error: #error "wxUSE_IFF must be defined."
/usr/local/include/wx/chkconf.h:408:9: error: #error "wxUSE_IMAGLIST must be defined."
/usr/local/include/wx/chkconf.h:416:9: error: #error "wxUSE_JOYSTICK must be defined."
/usr/local/include/wx/chkconf.h:424:9: error: #error "wxUSE_LISTBOX must be defined."
/usr/local/include/wx/chkconf.h:432:9: error: #error "wxUSE_LISTCTRL must be defined."
/usr/local/include/wx/chkconf.h:440:9: error: #error "wxUSE_LOGGUI must be defined."
/usr/local/include/wx/chkconf.h:448:9: error: #error "wxUSE_LOGWINDOW must be defined."
/usr/local/include/wx/chkconf.h:456:9: error: #error "wxUSE_LOG_DIALOG must be defined."
/usr/local/include/wx/chkconf.h:464:9: error: #error "wxUSE_MDI_ARCHITECTURE must be defined."
/usr/local/include/wx/chkconf.h:472:9: error: #error "wxUSE_MENUS must be defined."
/usr/local/include/wx/chkconf.h:480:9: error: #error "wxUSE_MSGDLG must be defined."
/usr/local/include/wx/chkconf.h:488:9: error: #error "wxUSE_NEW_GRID must be defined."
/usr/local/include/wx/chkconf.h:496:9: error: #error "wxUSE_NOTEBOOK must be defined."
/usr/local/include/wx/chkconf.h:504:9: error: #error "wxUSE_PALETTE must be defined."
/usr/local/include/wx/chkconf.h:512:9: error: #error "wxUSE_POPUPWIN must be defined."
/usr/local/include/wx/chkconf.h:520:9: error: #error "wxUSE_PRINTING_ARCHITECTURE must be defined."
/usr/local/include/wx/chkconf.h:528:9: error: #error "wxUSE_RADIOBOX must be defined."
/usr/local/include/wx/chkconf.h:536:9: error: #error "wxUSE_RADIOBTN must be defined."
/usr/local/include/wx/chkconf.h:544:9: error: #error "wxUSE_SASH must be defined."
/usr/local/include/wx/chkconf.h:552:9: error: #error "wxUSE_SCROLLBAR must be defined."
/usr/local/include/wx/chkconf.h:560:9: error: #error "wxUSE_SLIDER must be defined."
/usr/local/include/wx/chkconf.h:568:9: error: #error "wxUSE_SPINBTN must be defined."
/usr/local/include/wx/chkconf.h:576:9: error: #error "wxUSE_SPINCTRL must be defined."
/usr/local/include/wx/chkconf.h:584:9: error: #error "wxUSE_SPLASH must be defined."
/usr/local/include/wx/chkconf.h:592:9: error: #error "wxUSE_SPLITTER must be defined."
/usr/local/include/wx/chkconf.h:600:9: error: #error "wxUSE_STATBMP must be defined."
/usr/local/include/wx/chkconf.h:608:9: error: #error "wxUSE_STATBOX must be defined."
/usr/local/include/wx/chkconf.h:616:9: error: #error "wxUSE_STATLINE must be defined."
/usr/local/include/wx/chkconf.h:624:9: error: #error "wxUSE_STATTEXT must be defined."
/usr/local/include/wx/chkconf.h:632:9: error: #error "wxUSE_STATUSBAR must be defined."
/usr/local/include/wx/chkconf.h:640:9: error: #error "wxUSE_TAB_DIALOG must be defined."
/usr/local/include/wx/chkconf.h:648:9: error: #error "wxUSE_TEXTCTRL must be defined."
/usr/local/include/wx/chkconf.h:656:9: error: #error "wxUSE_TIPWINDOW must be defined."
/usr/local/include/wx/chkconf.h:664:9: error: #error "wxUSE_TOOLBAR must be defined."
/usr/local/include/wx/chkconf.h:672:9: error: #error "wxUSE_TOOLTIPS must be defined."
/usr/local/include/wx/chkconf.h:680:9: error: #error "wxUSE_TREECTRL must be defined."
/usr/local/include/wx/chkconf.h:688:9: error: #error "wxUSE_WX_RESOURCES must be defined."
/usr/local/include/wx/chkconf.h:696:9: error: #error "wxUSE_WXHTML_HELP must be defined."
/usr/local/include/wx/chkconf.h:1138:9: error: #error "wxMessageBox is always needed"
/usr/local/include/wx/chkconf.h:1184:9: error: #error "wxUSE_DYNAMIC_CLASSES must be defined as 1"
/usr/local/include/wx/string.h:442: error: ‘wxChar wxString::operator[](unsigned int) const’ cannot be overloaded
/usr/local/include/wx/string.h:429: error: with ‘wxChar wxString::operator[](size_t) const’
/usr/local/include/wx/string.h:446: error: ‘wxChar& wxString::operator[](unsigned int)’ cannot be overloaded
/usr/local/include/wx/string.h:437: error: with ‘wxChar& wxString::operator[](size_t)’
/usr/local/include/wx/object.h:438: error: ‘wxClassInfo’ has not been declared
/usr/local/include/wx/object.h:479: error: expected ‘;’ before ‘*’ token
/usr/local/include/wx/object.h:480: error: expected `;' before ‘void’
/usr/local/include/wx/object.h:480: error: ‘wxObjectRefData’ has not been declared
/usr/local/include/wx/object.h:498: error: ‘wxObjectRefData’ declared as a ‘virtual’ field
/usr/local/include/wx/object.h:498: error: expected ‘;’ before ‘*’ token
/usr/local/include/wx/object.h:501: error: ‘wxObjectRefData’ declared as a ‘virtual’ field
/usr/local/include/wx/object.h:501: error: expected ‘;’ before ‘*’ token
/usr/local/include/wx/object.h:503: error: expected ‘;’ before ‘*’ token
/usr/local/include/wx/object.h: In constructor ‘wxObject::wxObject()’:
/usr/local/include/wx/object.h:420: error: ‘m_refData’ was not declared in this scope
/usr/local/include/wx/object.h: In member function ‘void wxObject::SetRefData(int*)’:
/usr/local/include/wx/object.h:480: error: ‘m_refData’ was not declared in this scope
/usr/local/include/wx/object.h: At global scope:
/usr/local/include/wx/object.h:525: error: ‘wxClassInfo’ has not been declared
/usr/local/include/wx/object.h: In function ‘wxObject* wxCheckDynamicCast(wxObject*, int*)’:
/usr/local/include/wx/object.h:527: error: ‘class wxObject’ has no member named ‘GetClassInfo’
/usr/local/include/wx/gtk/gdiobj.h: In member function ‘bool wxGDIObject::IsNull() const’:
/usr/local/include/wx/gtk/gdiobj.h:29: error: ‘m_refData’ was not declared in this scope
/usr/local/include/wx/gtk/colour.h: In member function ‘bool wxColour::Ok() const’:
/usr/local/include/wx/gtk/colour.h:63: error: ‘m_refData’ was not declared in this scope
/usr/local/include/wx/font.h: In member function ‘bool wxFontBase::Ok() const’:
/usr/local/include/wx/font.h:104: error: ‘m_refData’ was not declared in this scope
/usr/local/include/wx/font.h: In member function ‘wxFontRefData* wxFontBase::GetFontData() const’:
/usr/local/include/wx/font.h:156: error: ‘m_refData’ was not declared in this scope
/usr/local/include/wx/gtk/region.h: In member function ‘bool wxRegion::Ok() const’:
/usr/local/include/wx/gtk/region.h:89: error: ‘m_refData’ was not declared in this scope
/usr/local/include/wx/gtk/icon.h: In member function ‘bool wxIcon::operator==(const wxIcon&) const’:
/usr/local/include/wx/gtk/icon.h:49: error: ‘m_refData’ was not declared in this scope
/usr/local/include/wx/gtk/icon.h:49: error: ‘const class wxIcon’ has no member named ‘m_refData’
/usr/local/include/wx/gtk/brush.h: In member function ‘bool wxBrush::Ok() const’:
/usr/local/include/wx/gtk/brush.h:48: error: ‘m_refData’ was not declared in this scope
/usr/local/include/wx/gtk/pen.h: In member function ‘bool wxPen::Ok() const’:
/usr/local/include/wx/gtk/pen.h:53: error: ‘m_refData’ was not declared in this scope
/usr/local/include/wx/gtk/dc.h: In member function ‘void wxDC::SetColourMap(const wxPalette&)’:
/usr/local/include/wx/gtk/dc.h:47: error: ‘SetPalette’ was not declared in this scope
ScripterCallback.cpp: At global scope:
ScripterCallback.cpp:49: warning: ‘visibility’ attribute ignored
ScripterCallback.cpp: In function ‘int ExtensionModuleInit(int)’:
ScripterCallback.cpp:147: warning: statement has no effect
make: *** [ScripterCallback.o] Error 1
