Can't build svn10729
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
ka1ssr
Post by ka1ssr » Wed Oct 13, 2010 4:15 am
I've been having trouble building 1.3.12 for a couple of weeks. Configure and make clean run fine, but make yields the following after a while...
Code: Select all
[lots of build messages]
libtool: compile:  gcc -c -I./include -I./src/common -I./src/os/unix -g -O2 -DPA_LITTLE_ENDIAN -pthread -DPACKAGE_NAME="" -DPACKAGE_TARNAME="" -DPACKAGE_VERSION="" -DPACKAGE_STRING="" -DPACKAGE_BUGREPORT="" -DPACKAGE_URL="" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DLT_OBJDIR=".libs/" -DHAVE_SYS_SOUNDCARD_H=1 -DHAVE_LINUX_SOUNDCARD_H=1 -DSIZEOF_SHORT=2 -DSIZEOF_INT=4 -DSIZEOF_LONG=4 -DHAVE_CLOCK_GETTIME=1 -DHAVE_NANOSLEEP=1 -DPA_USE_ALSA=1 -DPA_USE_JACK=1 -DPA_USE_OSS=1 src/os/unix/pa_unix_util.c -o src/os/unix/pa_unix_util.o >/dev/null 2>&1
/bin/sh ./libtool --mode=link gcc  -rpath /usr/local/lib -no-undefined -export-symbols-regex "(Pa|PaMacCore|PaJack|PaAlsa|PaAsio)_.*" -version-info 2:0:0 -o lib/libportaudio.la src/common/pa_allocation.lo src/common/pa_converters.lo src/common/pa_cpuload.lo src/common/pa_dither.lo src/common/pa_debugprint.lo src/common/pa_front.lo src/common/pa_process.lo src/common/pa_skeleton.lo src/common/pa_stream.lo src/common/pa_trace.lo src/hostapi/alsa/pa_linux_alsa.lo src/hostapi/jack/pa_jack.lo src/common/pa_ringbuffer.lo src/hostapi/oss/pa_unix_oss.lo src/os/unix/pa_unix_hostapis.lo src/os/unix/pa_unix_util.lo -lrt -lasound -ljack -lpthread -lrt   -lm -lpthread
eval: 1: libtool_args+=: not found
eval: 1: compile_command+=: not found
eval: 1: finalize_command+=: not found
eval: 1: libobjs+=: not found
eval: 1: non_pic_objects+=: not found
libtool: link: /usr/bin/nm -B   | sed -n -e 's/^.*[	 ]([ABCDGIRSTW][ABCDGIRSTW]*)[	 ][	 ]*([_A-Za-z][_A-Za-z0-9]*)$/1 2 2/p' | /bin/sed 's/.* //' | sort | uniq > lib/.libs/libportaudio.exp
/usr/bin/nm: 'a.out': No such file
libtool: link: /bin/grep -E -e "(Pa|PaMacCore|PaJack|PaAlsa|PaAsio)_.*" "lib/.libs/libportaudio.exp" > "lib/.libs/libportaudio.expT"
libtool: link: mv -f "lib/.libs/libportaudio.expT" "lib/.libs/libportaudio.exp"
libtool: link: echo "{ global:" > lib/.libs/libportaudio.ver
libtool: link:  cat lib/.libs/libportaudio.exp | sed -e "s/(.*)/1;/" >> lib/.libs/libportaudio.ver
libtool: link:  echo "local: *; };" >> lib/.libs/libportaudio.ver
libtool: link:  gcc -shared   /usr/lib/libasound.so -ldl -ljack -lrt -lm -lpthread    -Wl,-soname -Wl,libportaudio.so.2 -Wl,-version-script -Wl,lib/.libs/libportaudio.ver -o lib/.libs/libportaudio.so.2.0.0
/usr/bin/ld:lib/.libs/libportaudio.ver:2: syntax error in VERSION script
collect2: ld returned 1 exit status
make[2]: *** [lib/libportaudio.la] Error 1
make[2]: Leaving directory `/home/ka1ssr/audacity/lib-src/portaudio-v19'
make[1]: *** [portaudio-v19-recursive] Error 2
make[1]: Leaving directory `/home/ka1ssr/audacity/lib-src'
make: *** [audacity] Error 2
[email protected]:~/audacity$
I'm building under Ubuntu 10.10, but the problem was first noticed on 10.04. I can't remember exactly when I started having problems, sorry.
Thanks for your help.
Re: Can't build svn10729
Post by steve » Wed Oct 13, 2010 5:07 am
There is currently a problem and the developers are aware of it. The last version that builds on Ubuntu is r10709
Watch this thread for news:
http://sourceforge.net/mailarchive/foru ... city-devel
