Recording waveform variation
chris62
Post by chris62 » Thu Oct 07, 2010 10:55 pm
I seem to have an intermittent problem recording into Audacity. Scenario is that I record first side of vinyl album. This works fine. When I change album side the right hand channel doesn't record, even though I haven't pressed pause, merely turned the album and continued recording. On the attached image you can see the waveform stops recording the right at about 21 minutes. When I retried at the end, it recorded correctly (40 minutes on waveform). Can anyone shed some light? Cheers.
Waveform screen capture
Audacity screen.JPG (145.45 KiB) Viewed 631 times
billw58
Re: Recording waveform variation
Post by billw58 » Thu Oct 07, 2010 11:31 pm
Since you didn't hit pause or make any other change in Audacity, my guess is that your headshell on the turntable is loose or otherwise intermittent.
-- Bill
cnwtx
Post by cnwtx » Sun Oct 10, 2010 11:39 pm
I have had this same problem intermittently, however the LP will play fine on an separate analog stereo, while I am recording it on audacity.
-Cliff
chris62
Post by chris62 » Thu Oct 21, 2010 1:24 am
Thanks for the replies. I have checked the fittings and nothing feels loose.
Cliff, are you saying that your recording are fine in spite of the Waveform pattern. I can notice it on mine when I play it back.
The reason I am so fixated on this is I am undertaking a major project to digitalize my entire record collection (I am about 100 into 400 records) and I don't want to be repeating a mistake.
I am going to try trying taping from a different source (an Ion Tape Express) and reinstall Audacity if the problem persists.
It's the intermittent nature that make it such an issue. Sometimes it works fine for a session of taping, other times you tape one side of an album and the problem occurs.
Thanks again. I'll let you know how it goes.
cnwtx
Post by cnwtx » Fri Oct 22, 2010 1:32 am
chris62 wrote:Cliff, are you saying that your recording are fine in spite of the Waveform pattern. I can notice it on mine when I play it back.
I am not quite sure I understand what asking, however this problem does occur on several different inputs to the amplifier. (I still get stereo on the computer speakers when this problem is occurring).
-Cliff
