recording entire tape
onehappyneedle
Post by onehappyneedle » Thu Oct 07, 2010 4:48 am
I have a question. I am putting music from my cassettes one song at a time. Is there a way that I can copy the entire tape and then record it onto cd? Do I have to do one song at a time onto my computer and then put them on cd?
Thanks
I hope you can understand my question.
Naomi
billw58
Re: recording entire tape
Post by billw58 » Thu Oct 07, 2010 5:25 am
This tutorial in the Audacity manual will tell you how to copy an entire tape then export a separate file for each song suitable for burning to CD.
http://manual.audacityteam.org/index.ph ... iscs_to_CD
-- Bill
davehutton
Post by davehutton » Thu Oct 07, 2010 9:32 am
Hi,
I have a similar question. I would like to remove certain parts on the tape. How do I do this?
Regards,
Dave
billw58
Post by billw58 » Thu Oct 07, 2010 2:42 pm
davehutton wrote: I have a similar question. I would like to remove certain parts on the tape. How do I do this?
Select the audio you want to remove then use Edit > Delete to take it out. http://manual.audacityteam.org/index.ph ... =Edit_Menu
-- Bill
