See also...Simple explanation of punch-in (and resolving result to a single track) by "steve":
http://forum.audacityteam.org/viewtopic ... 43#p143400
punching in
Re: punching in
I figured out a super-easy way of doing this, without having to mess around with labels.
This will move a snippet from one track to another. I'm assuming you have two tracks: One with the mistake, and one recorded next to it that contains the fix.
- Select a region containing only the fix
- ctrl-alt-X to split-cut
- 'enter' to deselect the track with the fix (the selected region should still show up on the time-scale)
- up/down to navigate to the track that needs fixing
- 'enter' to select that track
- ctrl-V to paste
Done!
- ctrl-C to copy
- 'enter' to (also) select that track
- ctrl-V to paste
Done!
Re: punching in
You are absolutely correct - but why bother moving / copying everything to the same track? Audacity has multi-track capability, so why not use it?dan3h wrote:I figured out a super-easy way of doing this, without having to mess around with labels.
