Problems with Cut Preview
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
DickN
Post by DickN » Fri Oct 01, 2010 2:37 pm
I have 2 tracks, 1st one is muted. If both are selected, Cut Preview is muted for both tracks and the Play button stays pushed after the silent playback.
Also, occasionally when I hit 'c' to preview a cut, a label is created for the selected range and the 'c' is inserted as text. This is persistent when it's happening, but I haven't yet identified the conditions that produce it. It might involve having the label track included in the selection, but when I deselected the label track it didn't correct the problem.
Re: Problems with Cut Preview
Post by Gale Andrews » Fri Oct 01, 2010 3:02 pm
DickN wrote:I have 2 tracks, 1st one is muted. If both are selected, Cut Preview is muted for both tracks and the Play button stays pushed after the silent playback.
Thanks. This is already listed as Bug 231. Only the top track plays (or doesn't play if muted) and otherwise mute/solo state isn't respected.
DickN wrote:Also, occasionally when I hit 'c' to preview a cut, a label is created for the selected range and the 'c' is inserted as text. This is persistent when it's happening, but I haven't yet identified the conditions that produce it. It might involve having the label track included in the selection, but when I deselected the label track it didn't correct the problem.
If you have the label track focused with the yellow border (selected or not) a label will be produced with cut preview. That's expected and is one of the issues that you get if you allow a label to be created in a focused label track just by typing (rather than having to use the Add Label at Selection shortcut first of all).
I can't at the moment get it to produce a label after typing "C" unless the label track has focus.
Edgar
Forum Crew
Post by Edgar » Fri Oct 01, 2010 3:13 pm
Regarding the problem with creating spurious labels with keypresses which should launch events instead, I have a horrible problem with this about the only keypress that "usually" DOES NOT cause this problem is the spacebar (but even occasionally it happens too). I finally went through the entire keyboard preferences and removed all single key shortcuts (with the exception of Play) – for almost all of them I was able to make them ctrl+<KEY>. I realize that this is a non-optimal solution for most users.
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
Post by Gale Andrews » Sat Oct 02, 2010 5:41 pm
Edgar wrote:about the only keypress that "usually" DOES NOT cause this problem is the spacebar (but even occasionally it happens too).
P (or some other customised single key shortcut for Pause) also does not cause the problem if the track is playing or recording.
