Low level with Samsom C01U, Preference Problem?
cariocastyle
Post by cariocastyle » Tue Apr 22, 2008 5:17 am
Hi,
I installed Audacity and everything works fine except that when I record my voice, the level is very low (I can barely hear it on headphones when listening to the AIFF file)
I know this have been discussed before but I'm still confused after reading several posts...
Here is my configuration:
Windows XP
Mic : Samson C01U
On Audacity on preferences i have this:
Playback
either : microsoft sound mapper - output
or sound max digital audio
Record
either: Microsoft sound mapper input (the one i selected)
or Samson
or Sound max
What should I choose for Playback and Record ?
Why the level is so low? What else can I try?
Thanks a lot, I'm going crazy...
Re: Low level with Samsom C01U, Preference Problem?
Post by kozikowski » Tue Apr 22, 2008 7:17 am
You may be experiencing two problems conjoined. Since "zero" dB in digital sound level is the point at which you generate unrecoverable, audible damage, no designer in his/her right mind would design a microphone containing no live controls anywhere even close to that level. So that puts the standard mic level--wild guess now--at around -20dB. -18 dB is widely considered half audio volume to most ears, so that's already pretty quiet.
Then you connect that with computer sound services that no longer provide that all-too-handy 20dB sound boost that they used to. Now you could have sound in the -30 to -40 range. That's seriously quiet--especially compared to very highly processed modern music.
Samson claims that normal computer sound services should work just fine, but if they don't, Samson provides a third-party "Mic-Pre" (Microphone Preamplifier) package.
http://www.samsontech.com/main/misc.cfm?pageID=45
And for goodness sake, if you try it, tell us how it worked.
cariocastyle
Post by cariocastyle » Tue Apr 22, 2008 8:15 am
Thanks a lot.
I read many times in forums and reviews the recomandation from users to avoid installing the Samson "Mic-Pre", because it is very bugy and causes many problems in Windows...
Now what can I do ??
Are you sure there isn't something else I didn't set up right?
Thanks again.
cariocastyle
Post by cariocastyle » Tue Apr 22, 2008 4:31 pm
What about the preferences? :)
Playback
Record
or Samson
or Sound max
Thanks
cariocastyle
Post by cariocastyle » Tue Apr 22, 2008 5:12 pm
Found it about the level problem:
Tutorial here:
http://www.samsontech.com/usb_mics/xp_no_softpre/
http://forums.techsmith.com/showthread. ... 020&page=3
Still waiting for a reply about the PREFERENCES, is it better to select the sound card and the mic (Playback/Record) or the Microsoft Sound Mapper?
Thanks.
Post by kozikowski » Tue Apr 22, 2008 8:16 pm
We'll need to wait for one of the heavy Windows users to drop in. My Windows 2000 has different panels than you do.
